38R numbers - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 11-03-2008, 12:36 AM Thread Starter
HP Junky
38R numbers
Anyone know what a 38R will flow in lbs/min? It's a 64mm comp right?
RockinJW is offline
post #2 of 12 (permalink) Old 11-03-2008, 12:38 AM
Banning Smut
PTSUPERD's Avatar
Re: 38R numbers
I thought it was 66mm Jacob...?
PTSUPERD is offline
post #3 of 12 (permalink) Old 11-03-2008, 12:46 AM
Got Bost???
NyCowboy87's Avatar
Re: 38R numbers
garrett's map shows them at about 48-50lbs at peak efficiency, at 20 or so lbs of boost.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #4 of 12 (permalink) Old 11-03-2008, 01:03 AM Thread Starter
HP Junky
Re: 38R numbers
I'm not sure, thats why I'm asking. Would just like some specs on it, flow is more important than size. I'd like to know a peak flow in lbs/min or cfm
RockinJW is offline
post #5 of 12 (permalink) Old 11-03-2008, 01:15 AM
Got Bost???
NyCowboy87's Avatar
Re: 38R numbers
Peak flow at the most efficient part on the compressor map is at 48-50lbs/min at around 20lbs of boost. If you spin the hell out of it it will reach close to 70lbs/min but the efficiency drops off to around 60%.
Tow Mule
post #6 of 12 (permalink) Old 11-03-2008, 01:20 AM Thread Starter
HP Junky
Re: 38R numbers
Okay, thanks
RockinJW is offline
post #7 of 12 (permalink) Old 11-03-2008, 03:10 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: 38R numbers
Isnt the inducer on them like 62mm? I smell a compound setup waiting to happen.
Stock
PowerstrokeJunkie is offline
post #8 of 12 (permalink) Old 11-03-2008, 03:26 AM
Re: 38R numbers
PMRCM#1
slowleak is offline
post #9 of 12 (permalink) Old 11-03-2008, 07:55 PM
urbanwheeler's Avatar
Re: 38R numbers
http://www.turbobygarrett.com/turbob...esel_tech.html i finally found a bsfc number to start with for a diesel .38 and an a/f of 22:1 for low to no smoke.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #10 of 12 (permalink) Old 11-03-2008, 07:57 PM
Busy Busy
Marty's Avatar
Re: 38R numbers
They are 66 mm, or a 2.6 class turbo.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
