DI RR Driver Side Rear Port line routing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-01-2008, 08:42 PM Thread Starter
Orezona's Avatar
I think I've lifted the turbo in and out 10 times now. I can't get the turbo shroud (ATS ported) to clear the fitting/hose. I've been trying different angles with no luck.
Thanks in advance...
Orezona is offline
post #2 of 11 (permalink) Old 11-01-2008, 09:10 PM
fueled by Colecovision
golfer's Avatar
Garage
Re: DI RR Driver Side Rear Port line routing
...what was the question?
golfer is offline
post #3 of 11 (permalink) Old 11-01-2008, 09:12 PM
cota's Avatar
Where are you located? It's tight back there but you should be able to rotate the fitting so it or the hose doesn't hit, unless the hose is too short. I had an ATS turbo when I installed mine.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #4 of 11 (permalink) Old 11-01-2008, 09:22 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
almost done my DI RR kit..everything was great...doing line test i one dripping line on one of the feed fittings on the bowl..gave one more turn and the damn bowl split..any one got a spare bowl they want to sell??
Ron's power stroke is offline
post #5 of 11 (permalink) Old 11-01-2008, 09:38 PM Thread Starter
Orezona's Avatar
Indianapolis. I just can't get the fuel line to clear or be in the right spot so I can lay the turbo back in
Orezona is offline
post #6 of 11 (permalink) Old 11-01-2008, 10:56 PM
When I did my DI RR, I had the line that was up against the compressor housing. I have just a stock turbo if that makes any difference. Just recently I got back in there and messed around with it. I think I ran it under that wiring harness that is on that side, and it pulled it away from the compressor. Even after 7 or 8 months of being against the housing, there was no damage to the hose.
2003 7.3 XLT FX4, AFE Stage 2, Regulated Return, Bowl Delete, 3/8" line from tank to heads, Pre/Post Filters, Tank mods, DP F5: 60T, 80E, 120R, 6.0 IC, 6.0 Trans Cooler, Suncoast Shift Kit, Wicked Wheel, ITP Boost Annihilator, Di Procol Optix, Straight Pipe, CCV, 285/75/16 BFG AT's
breyrw is offline
post #7 of 11 (permalink) Old 11-01-2008, 11:04 PM Thread Starter
Orezona's Avatar
Good to know. Thanks a bunch.
Orezona is offline
post #8 of 11 (permalink) Old 11-01-2008, 11:11 PM
bigd4me2's Avatar
this is about the best picture i could get. i think i already had my ats housing on the turbo, and i did not remove the turbo to install the the di regulated return. hope this helps!
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #9 of 11 (permalink) Old 11-01-2008, 11:42 PM Thread Starter
Orezona's Avatar
Perfect. Thanks for taking the time to get me a pic.
Orezona is offline
post #10 of 11 (permalink) Old 11-02-2008, 12:21 AM
the line will go right underneath the intake for the turbo
PMRCM#1
slowleak is offline
