Oil Pressure issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 117 (permalink) Old 10-31-2008, 01:58 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Oil Pressure issues
On my way to work this morning coasting down a exit ramp the light came on and the gauge dropped to flat. Back in the throttle, the needle comes back up and light goes off. Bad sender maybe?
PTSUPERD is offline
post #2 of 117 (permalink) Old 10-31-2008, 03:07 PM
Proud PSN Sponsor
Deputydog's Avatar
Re: Oil Temp idiot gauge
Is it throwing a SES light? I'd say the sender would be a likely culprit.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #3 of 117 (permalink) Old 10-31-2008, 03:09 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Oil temp or oil pressure? I didn't think there was an oil temp on them
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #4 of 117 (permalink) Old 10-31-2008, 03:10 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Hasnt thrown the light yet....
PTSUPERD is offline
post #5 of 117 (permalink) Old 10-31-2008, 03:12 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Originally Posted by Charles View Post
Oil pressure, not temp. Look closely at the light, it's not temp, it's pressure.
And the reason it came on was because you lost oil pressure (lower than ~5-7psi) in the reservoir.
Not uncommon with dual pumps and no external feed line.
When the red light came on by the gauge it had a thermometer icon. Never even payed attention to that gauge before.lol
WTF am I losing oil pressure for ?????????
stock hpop
PTSUPERD is offline
post #6 of 117 (permalink) Old 10-31-2008, 03:20 PM
Lovin the Tuna
RedSmokey's Avatar
I have the same issue with a different guage on my gas s10. When im at idle for a min. the guage completely zero's out, basically dead, then as soon as i give it some gas and start going it goes to full then works it way back down to where its supposed to be... I was told its just the sending unit on its way out... my .02 (sorry couldnt be more help).
2001 F250
2000 F250
RedSmokey is offline
post #7 of 117 (permalink) Old 10-31-2008, 03:22 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
I would think if I was actually losing pressure the truck would die and/or SES light right?
PTSUPERD is offline
post #8 of 117 (permalink) Old 10-31-2008, 03:27 PM
Possibly a P1211 from lack of oil to the HPOP, but they will run with the exact same condition you discribed in your first post. I have seen it on a truck with a mechanical gauge installed and a confirmed 0 psi of oil pressure at idle, while still running/driving. I wouldn't have believed it if I hadn't seen it.
I would throw a mechanical gauge on yours and check it out.
-Michael
Michael
post #9 of 117 (permalink) Old 10-31-2008, 03:39 PM
OEM Moderator
Tom S's Avatar
I think I would also probably want to put a mechanical guage on it and check. That being said my sender went bad years ago and caused the gauge to drop off like that.
Tom
Tom S is offline
post #10 of 117 (permalink) Old 10-31-2008, 03:43 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Will do . I do know that there are zero performance issues. I beat the tar out of it on the way to work this morning. Ran great. Threw no hard codes.
PTSUPERD is offline
