what's the lowest psi you can run on a reg return? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-31-2008, 03:57 AM Thread Starter
The reason I ask is because I have a buddy that has been running between 25-35 w/ stage 2s. He swears that his truck runs better than it did when he was running 50-50. He said that it idles better, and still pulls hard on top. I haven't tried this, but I'm curious to see if anybody has actually tested running the pressure this low.
99 F350 CCLB
skav is offline
post #2 of 12 (permalink) Old 10-31-2008, 05:33 AM
Proud PSN Sponsor!
Strictly Diesel's Avatar
Re: what's the lowest psi you can run on a reg return?
My trucks will NEVER be set lower than 60psi!
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #3 of 12 (permalink) Old 10-31-2008, 05:36 AM Thread Starter
I'm right there w/ you Dennis. I was surprised that his truck even ran, but he said that it ran great. That's why I am curious to see what the lowest anybody has tested the pressure.
99 F350 CCLB
skav is offline
post #4 of 12 (permalink) Old 10-31-2008, 11:42 AM
DZL JIM's Avatar
I just tested fuel psi on some dyno runs a few weeks back.
Picked up about 4 hp and 45 ftlb going from 50 to 65 psi. Dropped hp going to 75 psi.
Seems 60 - 65 psi is the sweet spot for PSD's. DO NOT run that low of pressure as your buddy...
DZL JIM is offline
post #5 of 12 (permalink) Old 10-31-2008, 12:31 PM Thread Starter
Trust me, I wasn't planning on it. Got too much invested on the injectors. But...Has anybody ran lower pressure? Lower than 45?
99 F350 CCLB
skav is offline
post #6 of 12 (permalink) Old 10-31-2008, 01:41 PM
Proud PSN Sponsor
Deputydog's Avatar
My fuel pump went out earlier this year and the Airdog was moving enough fuel to start and keep the engine running with 0 psi showing on the fuel pressure guage.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #7 of 12 (permalink) Old 10-31-2008, 01:56 PM
racehauler's Avatar
My truck idles smoother at 35-40psi than it does at 65. I just have the bost reference on the regulator hooked up so that I get to 65 when boost comes up.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #8 of 12 (permalink) Old 10-31-2008, 02:04 PM
Send a message via AIM to JohnT
I thought if the pressure was under 40PSI it was damaging to the injectors?
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #9 of 12 (permalink) Old 10-31-2008, 02:26 PM Thread Starter
My buddy's rail pump went out just after he installed the FASS. He said that he suddenly notice that his truck started to idle a lot better. He realized that the rail pump was not working afterwards.
99 F350 CCLB
skav is offline
post #10 of 12 (permalink) Old 10-31-2008, 02:31 PM Thread Starter
That's kinda what I was thinking might work. Turn the pressure down and letting the boost reference bring it up.
How long have you been running that way?
Does anybody know what pressure international runs on the injectors?
99 F350 CCLB
skav is offline
