Big Boost - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-31-2008, 12:58 AM Thread Starter
Big Boost
If i just put headstuds in with no fire rings and with a stock head gasket what will i be good for as far as boost numbers? Could i run a H2E with mini mes and still be safe or no?
BigJake is offline
post #2 of 8 (permalink) Old 10-31-2008, 01:11 AM
you want some of this?
smorris's Avatar
Re: Big Boost
Im gonna go out on a limb here and say you'll be fine. I had stock gaskets never been off, with studs, and 230cc inj. and modded H2E making around 40-45 psi. Never had a problem with gaskets. Now the block was a different story. Then on second engine, same setup, with a girdle to help the block live.....rods broke( much bigger injectors with no retuning--my fault completely) . Make sure you got correct tuning for your setup, and most likley it will be fine. And DO NOT tq them above what is recomended by the man. If the box says 125 ft pds, tq them to 125 ft pds, not 130, not 140....------125
I only know this because I messed up and took my arp's to 135 or 140 based on bad info, whether misprint from box, or off the internet or wherever I got it, and ended up having to purchase another set of studs when one broke, and two more stretched.
And , if you can afford it, go with cometics.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #3 of 8 (permalink) Old 10-31-2008, 01:14 AM
Laces Out
bigrpowr's Avatar
Re: Big Boost
you'll be absolutely fine. you're talking 45 psi..all good .
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #4 of 8 (permalink) Old 10-31-2008, 02:39 AM
POWERSTROKER's Avatar
Re: Big Boost
How much boost is required before you need studs??
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #5 of 8 (permalink) Old 10-31-2008, 02:41 AM
OverFuelingForYourPlesure
pontiacross's Avatar
Re: Big Boost
I always heard 40 for studs. but how much boost before studs and stock gaskets wont hold
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #6 of 8 (permalink) Old 10-31-2008, 03:36 AM
Re: Big Boost
What does boost have to do with head studs? Cylinder pressure is what lifts heads, right?
TXstroker01 is offline
post #7 of 8 (permalink) Old 10-31-2008, 04:03 AM
Banning Smut
PTSUPERD's Avatar
Re: Big Boost
Roll with it.
PTSUPERD is offline
post #8 of 8 (permalink) Old 10-31-2008, 05:19 AM
Sponsor
MidTennPSD's Avatar
Re: Big Boost
So far so good on my obs, heads have never been off, stock gaskets and h-11's. Its been seeing around 50psi with a 66/76 H2E since mid summer no issues so far.
'02 F-250 CCSB Lariat 4x4 160's 38R
'97 F-250 5.9 CTD SCSB 4x4 XLT. [email protected] #2
'06 Jetta TDI Malone Stg 2 Tune
FullForceDiesel.com
615.962.8291
MidTennPSD is offline
