Diesel Innovations Up pipes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 10-30-2008, 03:20 PM Thread Starter
PeterB
Has anyone here installed the Up Pipes from Diesel Innovations? TN turbo took a dump and need to replace it. Going with a Garrett (should have in the first place). I want to replace the up pipes and go to a non-ebv pedestal. Anyway, the DI up pipes look like a quality item, but I'de like to get some opinions from those who have installed and used them.
Thanks
Peter
2000 F-250, 4x4 XLT shorty CC, AT, ISSPRO trans/pyro/boost, TTM, SCMT, AFE, HX, 2003 T-stat, Sonax/Tricum, 4 1/2" Donahoe lift with 315/70/R17 tires, 4" MBRP T-304 SS exhaust, Coolant filter
PeterB is offline
post #2 of 35 (permalink) Old 10-30-2008, 03:25 PM
Banning Smut
PTSUPERD's Avatar
Re: Diesel Innovations Up pipes
I run the ceramic coated versions on my truck. No more leaks!
Leaking stockers:
Note the soot on the motor:
PTSUPERD is offline
post #3 of 35 (permalink) Old 10-30-2008, 03:29 PM
CtG
Aren't they a bit bigger diameter as well?
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #4 of 35 (permalink) Old 10-30-2008, 06:41 PM
Easy to install,
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #5 of 35 (permalink) Old 10-30-2008, 06:52 PM
Layson's Avatar
they are sure nice. I am planning on a set sometime.
Layson is offline
post #6 of 35 (permalink) Old 10-30-2008, 07:46 PM
Busy Busy
Marty's Avatar
Wish I had some!
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #7 of 35 (permalink) Old 10-30-2008, 09:43 PM
Drink til she's cute
Thuglike's Avatar
Easy job. Taken care of a few Jersey boyz leaking up's
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #8 of 35 (permalink) Old 10-30-2008, 09:50 PM
Butt-Head
PHPDiesel's Avatar
As soon as I can afford it (once I get my welfare check from O-to-the-Bama) I'm gettin' some o' deez and duh heddahs as well. Maybe get summa doze Crowah rodz and sum high-bridz too.
They look like quality pieces and guess what, they certainly can't hurt. Besides, how many up-pipe donut and pipe replacements do you really want to do in the time that these would actually last and be leak free?
Cody
PHPDiesel is offline
post #9 of 35 (permalink) Old 10-30-2008, 11:45 PM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
I have a set. They are extreamly well built. I think every 7.3 needs a set of DI up-pipes. They are the best built up-pipes I have seen.
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #10 of 35 (permalink) Old 10-31-2008, 02:03 AM
Martin #6's Avatar
You'll be very happy with the DI up-pipes. Easy to install and the best out there.
2008 F-250 Lariat CC 4x4. EPA stock.
Martin #6 is offline
