Rods - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 10-30-2008, 01:27 AM Thread Starter
Busy Busy
Marty's Avatar
Rods
What set of aftermarket rods can you put in w/o rebalancing the crank?
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 25 (permalink) Old 10-30-2008, 01:36 AM
Proud PSN Sponsor!
Strictly Diesel's Avatar
Re: Rods
I personally wouldn't ever change the rods without rebalancing. I'm sure it's been done before, but the PSD is expensive enough that I'd rather do it right the first time.
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #3 of 25 (permalink) Old 10-30-2008, 01:49 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: Rods
Crowers.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #4 of 25 (permalink) Old 10-30-2008, 02:24 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: Rods
Technically, the big end and small end would have to be exactly the same weight as factory, and that will be hard to get. When i changed from 13:1 to 15:1 pistons, the pistons were 30 grams lighter than the old setup (which was balanced with a clutch) the guy took 10 grams off the big end of each rod, which brough it down within .01.
Stock
PowerstrokeJunkie is offline
post #5 of 25 (permalink) Old 10-30-2008, 02:38 AM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Re: Rods
Marty,
Just do it right and buy a core to build up and then you don't have to worry about it. Form there you can sell the old engine and re-coup your investment in the core.
Just to throw out some double talk I'd say with as heavy as everything is in our engines if things are a few grams off it won't matter like Dave says but Dennis is correct. Do it the best way to make it live longer.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #6 of 25 (permalink) Old 10-30-2008, 02:41 AM
Re: Rods
Marty i know a guy with a shop in Frederick county, MD (right near me), he had to make custom weights to get my crank to balance, he now has the stuff he needs to do it, mine was almost exact, he claimed NHRA motors require a balance factor of .2, mine was .01, near perfect. Made me happy :)
Stock
post #7 of 25 (permalink) Old 10-30-2008, 02:50 AM
green member
roosterdiesel's Avatar
Re: Rods
Sets of stock forged rods can be as much as 25g different on the small end....ask me how me and my machine shop know. Don't buy "matched" sets off ebay!
With the stock rods having that big of weight descrepencies between sets I would balance ANY rotating assembly in a PSD!!
Any body need a set of worked forged rods that won't balance without removing 25 and 26 grams off 2 of the rods small ends?
2001 F-250 handshaker
#54
Stealth HPOPs
Alliant ACs
Forged rods with other junk to make it work
Thanks to TDP, BDP, RDS, PHP and TDGrp
roosterdiesel is offline
post #8 of 25 (permalink) Old 10-30-2008, 02:52 AM
A Ghost these days.
mad_matt's Avatar
Re: Rods
Where in fredneck? I talked to a few shops that deal with diesels up there. Would you mind sharing the name. I have a few stockers that might need a re-build.
Got Boost?
Dynojet
13.152 @ 104.7 mph
mad_matt is offline
post #9 of 25 (permalink) Old 10-30-2008, 02:58 AM
Re: Rods
In Woodsboro, name is Gunther's machine shop. They did the boring and honing on my block, too. The guy who actually does the balance work is Dynamic Performance, he just stores his new 40k balance machine in the corner of the shop.. That guy's from out in hagerstown.
Stock
post #10 of 25 (permalink) Old 10-30-2008, 03:21 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Rods
Kris
How much does getting the rotating assembly balanced and align honed after girdle is installed cost?
You guys probably already know what I'm up to.
Elkton, Maryland
Marty is offline
