water temp - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-29-2008, 03:06 PM Thread Starter
water temp
so i pulled the factory water temp gauge out of my truck and threw in an auto meter. it reads about 210-220 all the time for temp. i threw the factory one back in and it read it was a little below normal on it. Is 210-220 when i should be on the motor or do i have issues?
Christian
sweet dually is offline
post #2 of 4 (permalink) Old 10-29-2008, 04:54 PM
sandnut's Avatar
Re: water temp
I ran at that temp when I had the 203 t-stat. Now with the stock t-stat I run around 200 or just over. That's with the sender in the port right by the t-stat.
02 CC 4x4. AFE stage 2, Magnaflow 4" exhaust, BTS tranny, live-tuned by Jody, AC singles, DI regulated return, Terminator HPOP, DR 4.5" lift & some other stuff...
sandnut is offline
post #3 of 4 (permalink) Old 10-29-2008, 05:36 PM
Re: water temp
Mine has a stock thermostat and my scangauge reads 210-220 also. Sounded a little high to me but must be normal.
2002 F250 cc sb 4x4 7.3/auto, TS chip, tymar, 4" exhaust, x-monitor, 35" toyo's(no lift).
greenlion is offline
post #4 of 4 (permalink) Old 10-29-2008, 08:27 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: water temp
Sounds normal from what I have seen.
Joe
CSIPSD is offline
