GT 42 and Mini mes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 10-29-2008, 02:23 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
GT 42 and Mini mes
Well, It looks like I'm finally stepping up to a 42. This should be done in the next 2 weeks or so.
I will be running this with standard Mini Mes for now. I have a choice of 1.01 and 1.15 housing. I'm thinking the 1.01 would be better for me.....but am not opposed to the 1.15 if it still would spool decent.
Also, keep in mind I live only a few feet above sea level.
Who is running a 42 with hybrids?
PTSUPERD is offline
post #2 of 29 (permalink) Old 10-29-2008, 02:28 PM
Busy Busy
Marty's Avatar
Re: GT 42 and Mini mes
I'm thinking of stepping up too, subscribing.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #3 of 29 (permalink) Old 10-29-2008, 02:58 PM
HP Junky
At sea level, it oughta work awesome. I had absolutley no problem spooling it with the 1.28 housing on it down in California. I think you'll like the 1.01 just fine.
Plus, Lott can retune you for it, get the fueling and trans stuff working right with it. I had to raise the mph on the t/c lock-up so it wouldn't snuff the charger out.
RockinJW is offline
post #4 of 29 (permalink) Old 10-29-2008, 03:04 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Ah so the other housing is a 1.28....
I think the 1.01 will be the ticket too. Did you ever run it with MMs....or just the SHOs and B Codes?
PTSUPERD is offline
post #5 of 29 (permalink) Old 10-29-2008, 03:12 PM
Snake Oil Salesman
mattr66's Avatar
Do you ever have a problem with it bouncing off the rev limiter if you don't have the lockup immidiately happen on the 1-2 shift? Our trucks will flare the converter if we don't lockup immidiately....
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #6 of 29 (permalink) Old 10-29-2008, 03:15 PM
HP Junky
No, the other housing I have is a 1.15. I got the charger from Lott with the 1.28, it was WAY too much at 4500ft. So I swapped in the 1.15 and it was still a little tough to get rolling. So I then put the 1.01 on it, works pretty good now.
I never ran it with Mini Me's. My buddy in Utah ran the journal bearing 4202 with the 1.01 on his OBS with Casserly hybrids and it was too laggy for him. He swapped it for the 4294 and couldn't be happier now. He's at 4300ft too though, and it was a journal bearing not ball bearing.
RockinJW is offline
post #7 of 29 (permalink) Old 10-29-2008, 03:16 PM
DSTRBD's Avatar
1.01 for drive ability. You want instant response, not more big end.
DSTRBD is offline
post #8 of 29 (permalink) Old 10-29-2008, 03:17 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Right Nate!
PTSUPERD is offline
post #9 of 29 (permalink) Old 10-29-2008, 03:19 PM
HP Junky
My converter holds solid (Thanks John). When the tuning was locking the converter right at the 1-2 shift it was too much on the charger and snuffed it out bigtime, so it had to repool. Moved lock-up a little later and got the charger to stay lit through all the shifts and lock-up and picked up 2 tenths at the track.
RockinJW is offline
post #10 of 29 (permalink) Old 10-29-2008, 03:25 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
Originally Posted by PTSUPERD View Post
Right Nate!
Exactly, not like he'll ever race it or anything.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
