Lowering CR, Has anyone tried... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-27-2008, 11:38 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Removing the lip completely off the top of the bowl, like the cummins and various other engines. And what size bowl is needed for 16:1 and 15:1 compression ratio's.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 8 (permalink) Old 10-28-2008, 01:06 AM
Plays with Motors
Machinist's Avatar
Re: Lowering CR, Has anyone tried...
Have not tried it, you can remove enough material to get to 15-16:1 without changing the swirl characteristics of the bowl.
CC's removed from the bowl to get to 15:1 or 16:1 will change depending on your quench distance, head gasket kit used, valve recession and relief work, it will be between 8-12cc which is why you need to measure all the other variables before cutting the pistons, or stick to a known combination.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #3 of 8 (permalink) Old 10-28-2008, 01:59 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Everything is going to be stock on this engine at least as far as deck height, gaskets, recession and no reliefs in the pistons with the stock cam.
Tow Mule
post #4 of 8 (permalink) Old 10-28-2008, 03:24 AM
HRT Performance
HotRodTractor's Avatar
You mean like this:
Just cleaned the lip of the bowl off, added valve reliefs and coated them.
I don't have my paperwork handy, but you'll still have decent compression doing that, mine is a bit different than what someone would have with the rest left stock, because of alterations I had done to the heads, valves, and the specific clearances I set the motor up for.
Jason
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #5 of 8 (permalink) Old 10-28-2008, 03:44 AM
Plays with Motors
Machinist's Avatar
HRT - what is the company that coated your crowns? And what specifically do they call the coating - temp rating? Over the years I have seen many ceramic crown coatings and they all have a different color, from almost clear on some to a dark brown even more than those you have shown.
2011 335i M-Sport
post #6 of 8 (permalink) Old 10-28-2008, 03:48 AM
Sponsor
Wow Jason, I seem to recognize that method from somewhere... Seems great minds think alike...
UNLIMITED_DIESEL is offline
post #7 of 8 (permalink) Old 10-28-2008, 10:27 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Yep just like that Jason.
Tow Mule
post #8 of 8 (permalink) Old 10-28-2008, 01:39 PM
HRT Performance
I'll find out which company coated them. I handed them to a machinist/diesel truck buddy of mine and he cut them the way I wanted and sent them out to the same place where he gets all of his stuff coated for his super street/mod truck.
2015 VW Jetta TDI
2006 VW Jetta TDI
