Why doesn't my pyro work? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 41 (permalink) Old 10-27-2008, 10:40 PM Thread Starter
Busy Busy
Marty's Avatar
It started out being an ISSPRO pyro that would act funky for a few minutes bouncing around and then eventually would just shut off.
Well I changed probes same problem, changed lead wires, same problem, changed gauge to autometer, same problem, changed ground, same problem and changed power to directly from the battery and now the gauge just doesn't even work now at all.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 41 (permalink) Old 10-27-2008, 10:43 PM
PSDfan99's Avatar
Re: Why doesn't my pyro work?
When you turn the ignition key to "on", does the needle jump up very quickly and then fall back down to rest?
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #3 of 41 (permalink) Old 10-27-2008, 10:57 PM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
i have isspro...there pyros suck. some times i have to flick the guage for it to work. Day one I had a bad amp box so they sent me another pyro guage and amplifier box. Now i have intermitent problem with the guage itself. especially at start up.....you have to flick it for it to start working.
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #4 of 41 (permalink) Old 10-27-2008, 11:14 PM
Proud PSN Sponsor
Deputydog's Avatar
I have to agree, Isspro pyro suck.. Mine jumps all over the place!
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #5 of 41 (permalink) Old 10-27-2008, 11:46 PM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Is the probe an AutoMeter or isspro??? could they not be compatiblewith eachother? Better yet just bring the rag down and we're re-wire the thing right.
On second thought We should have added that to the fall brawl weekend work load.
Run an continuity test through the 2 wires that run to the probe. If it fails there is an open somewhere.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #6 of 41 (permalink) Old 10-27-2008, 11:49 PM
PSDfan99's Avatar
If the needle jumps quickly when you first put the key "on" and then goes back to rest, there is a brake in the circuit.
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
post #7 of 41 (permalink) Old 10-28-2008, 12:53 AM
Doakster's Avatar
I have the same issue, but mine has normally worked, but I have however blown the 5 amp fuse that is inline with all my gauges two times now. I went back and checked all my connections, resoldered the tips of the wires that going into amp box so the little screws would clamp down on the wires better. I'm still not sure if this will take care of it.
I'm just waiting to see if when the needle jumps, the fuse blows at the same time.
2003 F-350 4x4 SC 7.3, WOP QSSB Turbo, Isspro Gauges, MBRP 4 inch, AFE Stage II, , DP Tuned Stock, HI, 40t, 60t, 80t, 80e, 120R, 140ex, 6.0 Trans Cooler, 08 Tow Mirrors, 35in Kumho Mts
1993 International 4600 Dump, 7.3 IDI
Doakster is offline
post #8 of 41 (permalink) Old 10-28-2008, 01:20 AM
PSDfan99's Avatar
I talked to Diesel Manor for a while one day about my tranny temp gauge not working and how pissed I was. Then they asked me to check and see if the needle bounced up real quick when i turned the key on... and the needle did. So they said I undoubtedly have either a short in the system, broken wire, bad connection or the temp probe is internally damaged. So I crawled under my truck to find a bad connection with the wires and after soldering the connection up I was ready to go and the gauge worked great. I would assume a pyro should work the same.
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
post #9 of 41 (permalink) Old 10-28-2008, 01:23 AM Thread Starter
Busy Busy
Marty's Avatar
I had an isspro pyro, isspro wires, isspro booster boxes, isspro gauges.
Now I have Autometer pyro, wires, new power and ground and an autometer gauge. wtf.
Elkton, Maryland
Marty is offline
post #10 of 41 (permalink) Old 10-28-2008, 01:28 AM
Doakster's Avatar
Where did you end up doing the soldering? I know that you are talking about the trans temp bouncing (which mind does not), just my EGT gauge bounces.
I actually have the weather pack connections which I put dielectric grease in so there should be no "connection" points going back to the amp box, just the wires that go right back to the box. I'm still kinda stump on this one and I think that this is ultimately the cause of my blown fuses, due to the inrush of current that is happening somewhere in the circuit and shows up when the needle bounces.
Doakster is offline
