fuel mileage sucks after FASS install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 10-27-2008, 04:08 PM Thread Starter
so this past weekend i drobe approximately 450 miles. i averaged 14.6 mpg, WAY down from the normal 21 mpg. only thing i can think of that ive changed right before this was adding a FASS 150/180 and a new power steering pump. oh and i put on regular 4" exhaust and took the stacks off (big mistake BTW, stacks are the shizz).
can the FASS really make that much of a difference if any at all? i checked every single fitting for leaks and cant find any. fwiw, on the way back from houston i towed an empty trailer and got almost 17 mpg. now unloaded i cant even get 15 mpg.
any ideas??
PMRCM#1
slowleak is offline
post #2 of 22 (permalink) Old 10-27-2008, 04:21 PM
Snake Oil Salesman
mattr66's Avatar
Re: fuel mileage sucks after FASS install
what is your fuel pressure?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #3 of 22 (permalink) Old 10-27-2008, 04:40 PM Thread Starter
60ish
PMRCM#1
slowleak is offline
post #4 of 22 (permalink) Old 10-27-2008, 04:41 PM
PSN Po-Po
KrayzKajun's Avatar
you have a short between the steering wheel and the seat!
wht did you brake now doug??
2011 Ram 3500 C/C Dually 4x4
6.7L Cummins HO
Originally Posted by slowleak View Post
Take a stack, and stuff a cat in it. viola! cat stack.
KrayzKajun is offline
post #5 of 22 (permalink) Old 10-27-2008, 04:41 PM
Banned
Didn't you change something with the tranny?
TCC locking up correctly?
Charles is offline
post #6 of 22 (permalink) Old 10-27-2008, 04:44 PM Thread Starter
yes i changed th whole thing lol. built tranny from DI, but in between the time i did the tranny to the time i did the FASS i was getting the 21 mpg.
as far as i know its locking properly, locks harder than the stocker ever did, thats for sure, and at the same speed it normally did before too.
PMRCM#1
slowleak is offline
post #7 of 22 (permalink) Old 10-27-2008, 04:58 PM
Banned
Gotcha.
I just don't see the fuel pump doing this. I would search my memory long and hard to see if you may have changed something else.
Same program?
Charles is offline
post #8 of 22 (permalink) Old 10-27-2008, 05:02 PM
Banning Smut
PTSUPERD's Avatar
Ditto. Doubt it's the Fass Doug.
PTSUPERD is offline
post #9 of 22 (permalink) Old 10-27-2008, 05:03 PM Thread Starter
same thing i was thinking.
i just dont remember changing anything but that. maybee matt will remember something i dont.
PMRCM#1
slowleak is offline
post #10 of 22 (permalink) Old 10-27-2008, 05:35 PM
Banned
I figured it out...
Slim's got your line pressure at 100% from anything right off idle to try and keep that tranny alive.
It's sucking the power right out of the truck to turn the pump.
Charles is offline
