Plug sealant help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-27-2008, 03:05 AM Thread Starter
Subject Matter Expert
PowerstrokeJunkie's Avatar
Plug sealant help
Just wanted to advise people not to use liquid thread sealant, or at least the type i got. I got the truck running today and traced the problem down to a plug on the back of the block leaking, that requires dropping the tranny, removing the flex plate/rear main seal plate to get to it...
Just wondering if you all just use teflon tape, or something else to seal these plugs up goo... TIA
Stock
PowerstrokeJunkie is offline
post #2 of 13 (permalink) Old 10-27-2008, 03:21 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Re: Plug sealant help
I use teflon tape to prevent having dope get in and plug things up.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #3 of 13 (permalink) Old 10-27-2008, 03:31 AM
OEM Moderator
Tom S's Avatar
I use paste a lot with no issues. I have issues with tape turning to goo.
Tom
Tom S is offline
post #4 of 13 (permalink) Old 10-27-2008, 03:34 AM Thread Starter
I am hoping for the better, there's oil leaking somewhere between the back of the engine and the TC, getting moved all around inside the bellhousing, isn't coming from up top at the valley drain hole. Ill drop the tranny tomorrow and investigate, hoping for the best.
Stock
post #5 of 13 (permalink) Old 10-27-2008, 04:17 AM
<- Sums it up
strokin_early_99's Avatar
I use teflon paste that the steam fitters use. Never had an issue yet, I use it on everything from the oil system to the fuel system. Never had a leak with this stuff.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #6 of 13 (permalink) Old 10-27-2008, 04:18 AM
Drink til she's cute
Thuglike's Avatar
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #7 of 13 (permalink) Old 10-27-2008, 04:58 AM
Needs more hours per day
jtharvey's Avatar
Can you get this stuff at the local hardware store or have to get it from a specialty place? Is it marked specifically for steam?
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #8 of 13 (permalink) Old 10-27-2008, 06:25 AM
<- Sums it up
I will get the name of the stuff when I get home from work tomorrow. I get it from my local Ace hardware but most call it a speciality store, it has a little of everything.
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #9 of 13 (permalink) Old 10-27-2008, 10:24 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
Is it called RECTOR 5 thread sealant ?
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #10 of 13 (permalink) Old 10-28-2008, 03:39 AM
bigd4me2's Avatar
permatex makes a liquid in a tube.
been using it for many years. but i use blue locktight for fuel.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
