high flow turbine housing outlet question.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-25-2008, 03:31 PM Thread Starter
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
This outlet is approximately 3.25" ID compared to the stock outlet which is approximately 2.75" ID. is this the only difference ?? or is something done to the waste gate side too??
Ron's power stroke is offline
post #2 of 10 (permalink) Old 10-25-2008, 10:09 PM
tkdbf350's Avatar
Re: high flow turbine housing outlet question..
No flapper.
2006 F350 CC/LB Lariat FX4, MBRP 4in
2003 F350 standard cab DRW 6spd FX4, aFeII, straight piped duals, DP Tuner Stock, 60T, 80E, 140 Agg, BDP 160cc singles, SBC, ISSPRO A-Pillar gauges boost and egt, ITP Overboost Annihilator, 1.00 Ex. Housing, Wicked Wheel, ITP Pre-pump/In-tank Kit, A/C valve, coolant filter.SOLD
tkdbf350 is offline
post #3 of 10 (permalink) Old 10-26-2008, 03:37 AM
yes it is that simple- I like my 3
00 F350- intake,exhaust, pi convertor/ trans
00 F550- dump, intake,exhaust....TN BB exh coated, pi convertor/trans
01 F350- dump, intake,exhaust, BTS v/b, torque conv.
03 F250- CC SB- 5.4 gas
(2)- 06 Dodge 2500 CC 5.9 twins/trans/tunes/fuel
03 dodge drag 10.5 fuel only
jsf350 is offline
post #4 of 10 (permalink) Old 10-26-2008, 07:35 PM Thread Starter
could a guy have a stock one. machined to 3" ? or does it have to be casted to that size??
post #5 of 10 (permalink) Old 10-26-2008, 09:52 PM
Electrical Nomad
Mayday's Avatar
when i got my non-ebv outlet i thought it was going to be bigger, advertised as high flow. it was only 2.75 but it looks like it was machined factory to that size. i was already contemplating getting mine machined out to the bigger dimension, i am sure it wouldnt be a problem.
2000 F250- hybrids, GT38R, ATS trans, mod IDM, ITP fuel system, and DP tunes.
Mayday is offline
post #6 of 10 (permalink) Old 10-26-2008, 10:03 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Keep in mind high flow does not mean bigger.
For example a 3.5 DP will outperform a 4" DP with a stock or 38R.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #7 of 10 (permalink) Old 10-26-2008, 10:15 PM Thread Starter
does this mean just gut the EBPV and go with that??
post #8 of 10 (permalink) Old 10-26-2008, 10:20 PM
For anything under 500rwhp yes.
Now if your looking for that last few HP, plug the holes in the original outlet or buy a non ebv one and have a machine shop taper bore it to the max size at the outlet.
David Lott
post #9 of 10 (permalink) Old 10-26-2008, 10:25 PM Thread Starter
sounds like this mod is done....thanks for your help...
post #10 of 10 (permalink) Old 10-26-2008, 10:25 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
I have a GDS(I think) for an SD and it has a significantly larger I.D. than the stock one. Some much larger that it leaks past where it mates to the turbine housing. You can hold them up together and see light through it.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
