1.15 torque specs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-21-2008, 10:15 AM Thread Starter
1.15 torque specs
I am about to install the 1.15 housing on my 38r and would like to know the torque specs. Does anyone know these or where I could obtain these #s?
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #2 of 16 (permalink) Old 10-21-2008, 11:44 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: 1.15 torque specs
Torque spec is 200 in-lbs, but VERY tight is what i like to use.
Stock
PowerstrokeJunkie is offline
post #3 of 16 (permalink) Old 10-21-2008, 03:19 PM
where did you get your housing?
PMRCM#1
slowleak is offline
post #4 of 16 (permalink) Old 10-21-2008, 04:28 PM
Proud PSN Sponsor
Deputydog's Avatar
I have some..
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #5 of 16 (permalink) Old 10-21-2008, 05:18 PM
Proud PSN Sponsor
Deputydog's Avatar
In case anyone else is looking for one.. Just make sure to also select the adapter from the drop down menu.. You will need the housing + adapter.
http://www.dieselpowerproducts.com/s...hp?id=318&=SID
820 HP on 05/19/12
post #6 of 16 (permalink) Old 10-21-2008, 06:11 PM
fbilly420's Avatar
Is the 1.15 van turbo housing the same as the 38R 1.15 housing your selling?
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #7 of 16 (permalink) Old 10-21-2008, 06:15 PM
Back to Civilian Life!!
MILFORD's Avatar
Does the adapter flange rid you of the EBPV?
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #8 of 16 (permalink) Old 10-21-2008, 06:17 PM
Proud PSN Sponsor
Deputydog's Avatar
No they are not the same, a van turbo adapter will not work. It will bolt to the housing, but not to the exhaust down pipe.
The flange you get from us will be the correct one (I know its called a van adapter on the site, we will change that).. Its billet steel.
I installed a 1.15 housing about 2 weeks ago on my truck and love it! Dropped my egt's, my turbo spools just as quick, if not quicker and its cleaned up the smoke more.
820 HP on 05/19/12
post #9 of 16 (permalink) Old 10-21-2008, 06:19 PM
Proud PSN Sponsor
Deputydog's Avatar
Yes it does!
Here is a picture of the adapter.. No EBPV!
http://rides.webshots.com/photo/1345...31720211lPqlwx
820 HP on 05/19/12
post #10 of 16 (permalink) Old 10-21-2008, 06:25 PM
Busy Busy
Marty's Avatar
I just got the adapter. Nice part!
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
