EGTs High!?!? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-21-2008, 03:20 AM Thread Starter
Back to Civilian Life!!
MILFORD's Avatar
EGTs High!?!?
I have my 38R on my truck now with some reman stage IIs from Cass and a BTS. I can hit 1400* and its not difficult to do. I have my waste gate unplugged and I am only hitting 29 or 30 PSI MAX. My injectors are not running the full fuel that they could and I have my timing on the chip brought back a little more then a usual program for stage IIs seeing as I have PMRs still. Anybody help me with this?? My up-pipe doughnuts are new and there does not seem to be a boost leak anywhere, my turbo lights fast and hard and there is no soot anywhere under the hood. Does anybody have any suggestions for me to try out? I thought my EGTs would of been lower then this seeing as people make 500HP on the same turbo and I am only at about 350 with my tunes. Help me out.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #2 of 11 (permalink) Old 10-21-2008, 03:39 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: EGTs High!?!?
The injectors put out alot more fuel than stock. Get used to seeing high EGTs quickly.
Stock
PowerstrokeJunkie is offline
post #3 of 11 (permalink) Old 10-21-2008, 03:44 AM Thread Starter
MILFORD's Avatar
Re: EGTs High!?!?
What about my boost numbers??? Shouldn't they be higher? I am thinking about taking out the turbo and getting a non waste gated 1.115 housing for it. That should drop me back down to the 1200* range. Not to worried about the little bit of lag with the bigger housing since I have so much fuel its not going to be a big deal at all.
MILFORD is offline
post #4 of 11 (permalink) Old 10-21-2008, 04:01 AM
What else?
smokyred's Avatar
Re: EGTs High!?!?
Yes, try a larger exhaust housing and see what it will do for you.
Dave
smokyred is offline
post #5 of 11 (permalink) Old 10-21-2008, 04:05 AM Thread Starter
MILFORD's Avatar
Re: EGTs High!?!?
I want to know some peoples current EGTs with a similar set up if I can get them.
MILFORD is offline
post #6 of 11 (permalink) Old 10-21-2008, 04:12 AM
Layson's Avatar
Re: EGTs High!?!?
You ought to just make a boost leak detector and see if you have any leaks? I know I had a few I didn't realize...every little bit helps..
It is pretty easy to make!
Layson is offline
post #7 of 11 (permalink) Old 10-21-2008, 04:18 AM Thread Starter
MILFORD's Avatar
Re: EGTs High!?!?
I have made one before. I will have to do that to check.
MILFORD is offline
post #8 of 11 (permalink) Old 10-21-2008, 12:58 PM
Haulin' Iron
superih's Avatar
Re: EGTs High!?!?
Have you tried adjusting your waste gate? Screw it in a couple turns and see if boost goes up.
'99 F-350 CC SB Lariat 4x4 Auto -DI chip-GTP38R-BPV delete-Zoodad-Suncoast tugger trans-6.0 trans cooler-Powerstop brakes-CCV-Gauges-Exhaust-AIS Intake-Kenwood sounds-
-Traveling the Earth 300 ft at a time-
superih is offline
post #9 of 11 (permalink) Old 10-21-2008, 03:08 PM
Re: EGTs High!?!?
sounds like boost leaks to me
PMRCM#1
slowleak is offline
post #10 of 11 (permalink) Old 10-21-2008, 05:37 PM
racehauler's Avatar
Re: EGTs High!?!?
You may have some other issues but keep in mind that less timing = higher EGT's. 1400 deg. isn't all that rediculous depending on how hard you are into the fuel pedal.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
