overboost? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-20-2008, 09:09 PM Thread Starter
JHill's Avatar
overboost?
friends truck '00, and has a BRV+ from Dieselste. same as on my truck.
I see 32# often and no CEL. are some trucks MAP sensors a little more sensitve than others? he was at 26# and cel light came on and boost dropped to 15#, after a bit light went out. PO238 code was what he pulled.
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #2 of 8 (permalink) Old 10-20-2008, 09:11 PM
you want some of this?
smorris's Avatar
Re: overboost?
He needs to check and lube his BRV. Sometimes they stick and wont relieve corrctly. Little WD 40 works great. Mine hits 50 psi with no light.
Tell him spray it, and work it some then respray.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #3 of 8 (permalink) Old 10-20-2008, 09:19 PM Thread Starter
JHill's Avatar
Re: overboost?
done that, its only a few months old. truck has less than 30k on it bieng a automagic can it boost quicker than the relief valve can open and spike?
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #4 of 8 (permalink) Old 10-20-2008, 09:31 PM
Village Idiot
southmike's Avatar
Re: overboost?
no
it does say dieselsite on it doesn't it
there were copies that didn't work so well.
also double check it is installed right , and that he is getting
an overboost code and not a hpop check engine light .
maxing out a stock hpop for 7 sec or so will set a different code.
(not knowing what the PO238 is off the top of my head)
southmike is offline
post #5 of 8 (permalink) Old 10-20-2008, 11:09 PM
WHAT???
STROKIN N STYLE's Avatar
Re: overboost?
had to do that to mine.....remember scott?
2000 F-250 ex sb 4x4 Swamped 7.3 (CR coming soon)
1999 F-450 cc fb 4x4 Swamped 7.3 (STOLEN)
2008 F-250 cc sb 4x4 H&S, S&B, 5", BMF, Grabbers
STROKIN N STYLE is offline
post #6 of 8 (permalink) Old 04-08-2009, 04:03 AM
Big J power stroke's Avatar
Re: overboost?
Have a diesel site boost relief valve & doesn't work half the time. Go's into de-fuel. Any ideas?
Big J power stroke is offline
post #7 of 8 (permalink) Old 04-08-2009, 02:05 PM
Village Idiot
southmike's Avatar
Re: overboost?
call bob
see if it is a dieselsite valve.he may exchange it.
or walk you through the install/ check for problems etc..
there were a few bad copies sold as dieselsite valves
that were not his which did not work.
post #8 of 8 (permalink) Old 04-09-2009, 03:50 PM
Re: overboost?
I swapped mine out for the ITP version and have never had any further issues...
Bighunter is offline
