Intercooler???????/ - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-20-2008, 12:08 AM Thread Starter
Intercooler???????/
I am trying to figure out how to get an intercooler on my van. I want to put one where the original grill is and hopefully overlay it with one of the billet offerings. But it will have to be radiused......
I have been emailing back and forth with the tech guy at bell intercoolers. To make a long story short, he says a 3.5" core, cross flow, 11" tall, and 28" wide is just enough. But that won't work for me because it needs to be "radiused" to fit the contour of the front of the van.
So will 3 cores work in this instance? Here is what I had in mind. This is drawn as 3 10" wide x 11" tall x 3.5".
What about vertical flow? These 3 cores flow a lot. Would the air even get cooled enough????
THose cores are only 6" tall.
Thanks.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #2 of 13 (permalink) Old 10-20-2008, 12:17 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Re: Intercooler???????/
Why couldn't you use the first design, if they were just cores that were welded together to match the radius you need? Doesn't seem like it would be much different than custom end tanks being welded on??? Maybe I'm way off here?
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #3 of 13 (permalink) Old 10-20-2008, 12:46 PM Thread Starter
In the top drawing, will the flow go way down because the cores aren't touching each other in the front?
I know the trucks use 3" tubing to the intercooler and back. Do you think I could get away with 2 1/2?
rpm-inc is offline
post #4 of 13 (permalink) Old 10-20-2008, 12:58 PM
Banned
You can definately drop the tube sizing on the return path, as there will be less CFM flow leaving the cooler than that entering.
Charles is offline
post #5 of 13 (permalink) Old 10-20-2008, 04:34 PM
utah get me two
i have a friend with a 98 4x4 van with a 7.3
we put in hybrids and a h2e(had it done)
he needs a cooler bad,as he cant use all his power.
i had many thoughts on a cooler config,the grill is kinda trianguler shaped,and i was thinking of haveing a cooler made the exact same shape,ther it would replace the grill.
biggest problem would then be,he would have a cooler for a grill,but maybe do up some small crome rods and fab up some kind of covering.
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #6 of 13 (permalink) Old 10-20-2008, 04:40 PM
ARMY bound
Water injection and be done with it.
bbbxcursion is offline
post #7 of 13 (permalink) Old 10-20-2008, 04:46 PM
Busy Busy
Marty's Avatar
Water injection x2
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #8 of 13 (permalink) Old 10-20-2008, 09:50 PM Thread Starter
Charles, are you serious or are you trying to say that cooler won't flow enough?
rpm-inc is offline
post #9 of 13 (permalink) Old 10-20-2008, 09:52 PM Thread Starter
Originally Posted by Maintain View Post
Water injection x2
I have a coolingmist kit sitting here waiting to go on. I want both, just like you truck guys get to have.
rpm-inc is offline
post #10 of 13 (permalink) Old 10-20-2008, 10:01 PM Thread Starter
That is pretty much what I have in mind, although maybe not the exact shape, of the grill.
Hopefully be able to cover it up with one of these.
What size core were you thinking about?
rpm-inc is offline
