make your own? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 10-19-2008, 05:01 PM Thread Starter
make your own?
Sorry I'm so dumb, but i was thinking can you make your own Regulated Return? has anyone done this? what would i need?
F-350 is offline
post #2 of 27 (permalink) Old 10-19-2008, 05:03 PM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Re: make your own?
You need a regulator, tubing and fittings. Then just put it together.
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #3 of 27 (permalink) Old 10-19-2008, 05:12 PM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: make your own?
With the cost to picking everything up, it comes to around the same as buying a kit
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
post #4 of 27 (permalink) Old 10-19-2008, 06:32 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: make your own?
Look here for the parts, hose lengths and diagram to build your own.
http://www.dieselinnovations.com/techfiles/reg-kit.pdf
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #5 of 27 (permalink) Old 10-19-2008, 08:06 PM
OEM Moderator
Tom S's Avatar
Re: make your own?
You might be happier in the long run just buying a kit from Diesel Innovations or ITP. I only built my own because I have an OBS truck.
Tom
Tom S is offline
post #6 of 27 (permalink) Old 10-19-2008, 08:09 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: make your own?
i bought that kit and its sitting on my shelf right now....but it has the black fuel lab regulator...very nice kit by the way..even came with the 4 point socket..very cool..I been looking all over for the install link today..and here it is...thanks...
where does the boost reference nipple plug into? and how does that work??
Ron's power stroke is offline
post #7 of 27 (permalink) Old 10-19-2008, 09:25 PM Thread Starter
Re: make your own?
you should send me that kit, so I can test it for you, make sure everything is working like it should
F-350 is offline
post #8 of 27 (permalink) Old 10-19-2008, 09:29 PM
Re: make your own?
LMAO..tell ya what..I'll give ya the parts i take off to put this kit on ...
post #9 of 27 (permalink) Old 10-19-2008, 11:29 PM
Re: make your own?
I think most people leave this disconnected and dial in a static pressure to their liking (~65psi or whatever).
We have mine connected to the intake Y pipe. The base fuel pressure is dialed in at ~45psi and we have a "boost fooler" valve in-line so that the regulator sees no more than about 20 psi of reference. This is an attempt to extend the life of the pump (A-1000), as the fuel pressure stays in the 45-50psi range while cruising, but climbs up (at a rate of 1 to 1 with boost pressure) to ~65psi when I get on the throttle. It seems to work great.
I have to give credit to Matt R., as this was his idea...
-Brent
TXstroker01 is offline
post #10 of 27 (permalink) Old 10-19-2008, 11:36 PM
Re: make your own?
thanks for the explanation.. i have ITP OBA in mine but could T into the line before the OBA..my boost gauge is in my AIH delete plug on the Y pipe.. is it just a matter of pluging it in??
