AFE II Non PG7 Filter cleaning - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-16-2008, 11:52 PM Thread Starter
matthewd11's Avatar
Are these filters able to be cleaned like the K&Ns? I have a K&N filter recharge kit that i could use. I am not sure if AFE has their own, or if you can use the K&N kit. Does anyone know if you can use the K&N recharge kit on these? I imagine they are all the same. Or must you just buy a new filter because they are not able to be cleaned?
matthewd11 is offline
post #2 of 13 (permalink) Old 10-17-2008, 12:24 AM
DILLIGAFF
Send a message via AIM to Redfish
Re: AFE II Non PG7 Filter cleaning
I cleaned my AFE stg 2 on my 7.3 all the time using K&N stuff. works the same imo
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #3 of 13 (permalink) Old 10-17-2008, 12:31 AM Thread Starter
matthewd11's Avatar
Did you have the PG7 element or just the regular?
post #4 of 13 (permalink) Old 10-17-2008, 03:09 AM
<-- GO BRONCOS
dblamp's Avatar
AFE says not to use K&N oil on their filters, but I don't know if it will really hurt anything if you do- the two oils they use can't be that different.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #5 of 13 (permalink) Old 10-17-2008, 03:22 AM
2nd class citizen
1snotrocket's Avatar
i use the k&n air filter cleaner to help brake the oil down.then i rinse the filter with a garden hose.then put the filter in a bucket with simple green and water mixture let filter sit for an hour so in mixture.do a final rinse with fresh water from the garden hose.then air dry over night. lube the filter with k&n or afe air filter oil and let sit for 30 minute and re install.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #6 of 13 (permalink) Old 10-17-2008, 10:19 AM
Don't see what it will hurt. Been using the K&N stuff for years on AFE, UNI, Twin Air ect.
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #7 of 13 (permalink) Old 10-17-2008, 01:40 PM
fbilly420's Avatar
I dont see how it would hurt it. AFE just wants you to buy their recharge kit I'm sure.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #8 of 13 (permalink) Old 10-17-2008, 03:06 PM
Banned
To the one guy with the elaborate cleaning procedure...
What in the hell do you do in the 24hrs you don't have a truck? Or do you buy two filters so that one can be cleaning while you're driving the other?
Charles is offline
post #9 of 13 (permalink) Old 10-17-2008, 03:10 PM
All done now
Arisley's Avatar
Just give me a paper filter. Change in 30 seconds, take it out and tap it out every so often. Done. I have a lot better things to do than spending a lot of time cleaning filters.
Arisley is offline
post #10 of 13 (permalink) Old 10-17-2008, 03:14 PM
Banned
Unfortunately, some people don't have 3 cubic feet of room under their hood to dedicate toward a paper filter that will still flow 2000CFM without pulling a hanus vacuum.
I like paper. But there's just no room.
Oh, not to mention paper looks stupid. That's not supposed to matter, but it does.
Charles is offline
