Common Rail 7.3 Conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 10-16-2008, 08:51 PM Thread Starter
moore20017.3's Avatar
I am in the early stages of the long process of building a pulling/drag motor. I am still in the phase where everything looks good on paper. So it might be a pipe dream still.
I am trying to locate a Duramax motor to retrofit the Bosch ECU, injectors and CPS to a 7.3 PSD. I thought about using a 6.4 system, but the Duramax will be more readily available at this point in time.
I know I have seen some thought on the injector length difference between the different series on DM motors. There is a difference in injector lengths with one being more accaptable in length to fit our heads.
I am still investing money into the HEUI system for the red truck, but I want to do one a little more extreme for next year. Mechanical injection I considered pretty hard, but the cost will be equal to more than what I'm thinking the CR will end up.
Has anyone else tried this? Lets hear some thoughts on it.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #2 of 40 (permalink) Old 10-16-2008, 08:57 PM
Banned
Re: Common Rail 7.3 Conversion
I want to know how people are getting the spray angles worked out. All engines with CR injectors are 4v heads.
Charles is offline
post #3 of 40 (permalink) Old 10-16-2008, 09:01 PM Thread Starter
That would be good information, I can't answer. How similar or differant are the fuel bowl in the pistons?
post #4 of 40 (permalink) Old 10-16-2008, 09:06 PM Thread Starter
Here is a picture of a Dura piston. Discuss.
post #5 of 40 (permalink) Old 10-16-2008, 09:09 PM
Banned
The piston bowl is largely irrelevant to what I'm asking. I'm talking about the fact that the injector is meant to sit 90 degrees to the piston face in a 4v head, and will have to sit at an angle off to the side of the piston in a 7.3 head.
With the same nozzle it will be spraying the middle of the bowl and the opposite wall.
Charles is offline
post #6 of 40 (permalink) Old 10-16-2008, 09:13 PM
Oooo, White Lightning !
Dieselboy's Avatar
My question to the guys doing this is: Do you think its really worth it ?
For the amount of money for all the custom machine work for a extra few hundred HP........
For the price you could just as easily put a CR 5.9 in it......
Im all for advance on the 7.3 but this seems like a rediculous amount of time and money........Whats DOT got into his motor 100,000 $ ?
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #7 of 40 (permalink) Old 10-16-2008, 09:14 PM Thread Starter
Well, I thought 7.3 was on center of cylinder and 90* to the head. I did not know this.
post #8 of 40 (permalink) Old 10-16-2008, 09:16 PM Thread Starter
Machine work is basically free for me. Have access to many CNC machines. Now for the EH work on custom nozzles, I'm out of luck. But the injector sleeves and mounting for the CP-3 no problem.
Thought about a conversion, not gonna do it, gotta be a psd.
post #9 of 40 (permalink) Old 10-16-2008, 09:19 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
That might be why the ones doing fuel system conversions have gone mechanical, not common rail.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #10 of 40 (permalink) Old 10-16-2008, 11:11 PM
You still have the same issues. The injector spray angles aren't going to be off-the-shelf correct. An E9 nozzle would probably be the closest match for nozzle angle, but it's still going to need work I'd think.
69W900A is offline
