turbo shaft slop - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-16-2008, 12:53 AM Thread Starter
Electrical Nomad
Mayday's Avatar
turbo shaft slop
so is it normal to have more side to side slop on a BB turbo compared to a non BB turbo? i jusy got my brand new 38R and it has a lot more movement sid to side compared to my stocker. is it because of the bearings needing more space for oil once it gets oil pressure?
2000 F250- hybrids, GT38R, ATS trans, mod IDM, ITP fuel system, and DP tunes.
Mayday is offline
post #2 of 8 (permalink) Old 10-16-2008, 01:16 AM
fueled by Colecovision
golfer's Avatar
Garage
Re: turbo shaft slop
basically yes.
The only shaft play that is OK & normal is the side to side (as long as the wheels aren't touching the housings, obviously)
...once the shaft is sitting on a film of oil it centers itself in the center section.
in & out play is not so good, as it means that the thrust bearing has a little wear/slop in it.
golfer is offline
post #3 of 8 (permalink) Old 10-16-2008, 01:20 AM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #4 of 8 (permalink) Old 10-16-2008, 01:25 AM Thread Starter
Electrical Nomad
Mayday's Avatar
thanks i just wanted to be sure. my stomach sank when i felt it, and then i started thinking about the oil aspect, so i figured i better ask before i toss it in there.
Mayday is offline
post #5 of 8 (permalink) Old 10-16-2008, 02:12 AM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
You can send it to me and I will test it out for you.
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #6 of 8 (permalink) Old 10-16-2008, 02:21 AM Thread Starter
Electrical Nomad
Mayday's Avatar
right now i couldnt afford to ship it to you after takin that hit.
Mayday is offline
post #7 of 8 (permalink) Old 10-16-2008, 04:24 AM
6.4's are my Hero.
Reubine's Avatar
Haha I bet!!!
Reubine is offline
post #8 of 8 (permalink) Old 10-16-2008, 04:36 AM
99redf350's Avatar
#### ill pay for shipping to try it out
late 99 f350, guages, mbrp, cold air, SWAMPS 300/200 hybrids, gen 3, fuel lab, fuel regulator, gt42r and of course a ts tuner by swamps , currently broke
99redf350 is offline
