tn stage 2 turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 124 (permalink) Old 10-14-2008, 02:47 AM Thread Starter
2nd class citizen
1snotrocket's Avatar
tn stage 2 turbo
i have planned on using the tn stage2 turbo pedistal kit for my new truck. so i inquired about the stage 2 turbo and was told it has.
.76mm compressor housing
.68mm turbine housing
.84 a/r housing
what do you guy think about spool up and turbo lag as a daily driver and what size injectors would spool that turbo?
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #2 of 124 (permalink) Old 10-14-2008, 02:57 AM
What else?
smokyred's Avatar
Re: tn stage 2 turbo
You can buy the mount kit with multiple turbo options or no turbo at all. That 76mm would be a little laggy if you were using stock or small injectors.
Dave
smokyred is offline
post #3 of 124 (permalink) Old 10-14-2008, 03:00 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
T-66 would be great for a stock injectored truck. T-70 or T-72 for Stage 2 or hybrids...
Joe
CSIPSD is offline
post #4 of 124 (permalink) Old 10-14-2008, 03:02 AM Thread Starter
2nd class citizen
i was thinking bigger like b codes don't know what cc or nozzles yet but do like some input.
post #5 of 124 (permalink) Old 10-14-2008, 03:04 AM
CSIPSD's Avatar
T-72 for a DD, bigger if you dont tow or work it much...
Joe
CSIPSD is offline
post #6 of 124 (permalink) Old 10-14-2008, 03:09 AM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
depends on how big of b-codes. and what you are doing with the truck
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #7 of 124 (permalink) Old 10-14-2008, 03:11 AM Thread Starter
2nd class citizen
daily driver/racer no towing ever. all the towing is for my 03.
post #8 of 124 (permalink) Old 10-14-2008, 03:12 AM
Sponsor
how big of b-codes?
post #9 of 124 (permalink) Old 10-14-2008, 03:14 AM Thread Starter
2nd class citizen
well since i can get ddp at a sweet deal.thats what i was going to use. but don't know what cc they are.i was thinking .0085 or .010 tips.
post #10 of 124 (permalink) Old 10-14-2008, 03:22 AM
3's company
emtff7959's Avatar
Isnt the TN stage 2 basically an H2E with a fancy name?
For Sale.. Early 99 extended Cab long bed rare lariet F-350 Single rear wheel 6-speed Full leather power everything. PM me for information.
emtff7959 is offline
