EGT Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 10-13-2008, 03:52 AM Thread Starter
Canadian Powerstroker!
Oilfield_Digger's Avatar
EGT Questions
Ok I was driving on a flat hwy today with my sig truck with my quad in the back prolly about 1200 lbs in the box and I was getting 800 deg EGT's and 2-4 PSI boost at 70 mph. Oh and it was 57 deg F out.. Does this sound right? seems a little high to me considering the new turbo. Oh and I was running in the DP 80E tune...
03 7.3L F-350 Lariat FX4 CC LB
Mods: TN BB Turbo, NADP Heavy Hauler Tranny, DP F-5, Quad Pod w/ Autometer Phantom II's, AFE II PG7, AFE 409 SS 4" Exhaust, CCV, HPX, Non-EBPV & HFO, 95 Gal Aux tank/tool box, ITP OBA.
Oilfield_Digger is offline
post #2 of 22 (permalink) Old 10-13-2008, 03:57 AM
Loves OBS 7.3's
Sapps's Avatar
Re: EGT Questions
No problem with that...
95 F250 7.3 Fun
97 F250 7.3 Daily
07 3500 5.9 Work
02 F350 7.3 New Work Truck
Sapps is offline
post #3 of 22 (permalink) Old 10-13-2008, 04:32 AM
Firehunter's Avatar
Re: EGT Questions
No problem at all. If the road is truly flat, my EGT's are usually 10X the speed I'm going. 70mph = 700* EGT +/-
2000 F350 PSD, 4X4, CC, LB, 6-speed/ PHP Tuning /1.0 Turbo (no wastegate) with WW/ 4" turbo back exhaust/ AIS Intake with fender sleeve/ Isspro EV gauges/
Just because you can, doesn't mean you should!
Firehunter is offline
post #4 of 22 (permalink) Old 10-13-2008, 05:03 AM Thread Starter
Re: EGT Questions
I would have thought the TN would have dropped EGT's down to about 600 at least..
post #5 of 22 (permalink) Old 10-13-2008, 05:17 AM
squeak12's Avatar
Re: EGT Questions
I have similar mods as you, but I have 37" Toyo's and Bean's Stage I Injectors. at 70 mph, I'm pushing 800-1000 @ 4 psi.
2001 F-250 Crew Cab 4x4
squeak12 is offline
post #6 of 22 (permalink) Old 10-13-2008, 01:11 PM
Haulin' Iron
superih's Avatar
Re: EGT Questions
I noticed with my BB turbo that the EGT's run a little hotter than the stock turbo unloaded at cruising speeds. I just figured that the turbo isn't spooled enough I make about 2 psi less boost. Loaded it runs over 100F cooler.
'99 F-350 CC SB Lariat 4x4 Auto -DI chip-GTP38R-BPV delete-Zoodad-Suncoast tugger trans-6.0 trans cooler-Powerstop brakes-CCV-Gauges-Exhaust-AIS Intake-Kenwood sounds-
-Traveling the Earth 300 ft at a time-
superih is offline
post #7 of 22 (permalink) Old 10-13-2008, 01:18 PM
<-- it's like that
Re: EGT Questions
EGT changes aren't seen until you really get on the truck hard.
Also remember, you've gone from a .84 A/R turbine housing to a 1.0 A/R. Even though it might feel like it spools as quickly down low as the stock turbo, there is an actual difference. With the same amount of fuel, going to a larger turbine housing will increase turbo lag, and if you keep going bigger, you'll actually see EGT's at low load/low throttle increase (but at higher load/high throttle situations, EGT's will decrease). So there is a tradeoff somewhere in there.
But with what you have and the mods you are currently sporting, I wouldn't worry about it. Drive it and enjoy.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #8 of 22 (permalink) Old 10-13-2008, 01:42 PM
Lovin the Tuna
RedSmokey's Avatar
Re: EGT Questions
When im crusing around town (stock turbo) doing about 55, im a little under 600 i think running 2-3 pounds boost. My .02
2001 F250
2000 F250
RedSmokey is offline
post #9 of 22 (permalink) Old 10-13-2008, 04:51 PM Thread Starter
Re: EGT Questions
cool thanks guys.. now i am just gonna have to decide weather or not i am gonna get a boost fooler or not..
post #10 of 22 (permalink) Old 10-13-2008, 04:54 PM
matthewd11's Avatar
Re: EGT Questions
Just cruisng 65-70 on the highway, i run about 550-600* with hybrids .008 nozzles and a modded h2e (71mm compressor), 17cm housing, 4-5 psi boost.
matthewd11 is offline
