Fall Brawl Prep = Success! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-12-2008, 10:19 PM Thread Starter
Busy Busy
Marty's Avatar
Friday night Matt and I removed both turbo's and popped the injectors out of his truck and they are being sent off to be modified. Jay pretty much with little more then moral support and a few tool hand offs took out his factory HPOP. I also administered a compression test on Matt's truck. We called it a night and got up the next morning around 11 am.
By 12 Matt and Jay were busy installing the Stealth Stage 2 in his truck, and Steve showed up. Steve and I started tearing the top end of his motor apart and then did a contribution test on his truck as well. We then left for about 90 minutes to get his injectors and come back. When we got back we started doing the head studs. I was able to get 17 of 18 on that side no problem. Did 10 on the passenger side and couldn't get any further w/o moving the motor or vac housing. Well Matt and Jay finished up the stealth install and we watched it run for a bit. By this time it was getting dark and Matt, Jay, Steve and I started rocking the motor to get to the last driver side stud. To no avail. Finally we decided to leave it alone for a few minutes and went and removed the vac cover on the passenger side and we were able to get to every single bolt no problem with the motor in the frame rail. The hardest part was getting some of those far back ones to 135 ft/lbs when you have no leverage and you can only do one click at a time b/c of limited space. Anyway we finished that and decided to take another look at the driver side. After several attempts we decided the downpipe was in the way but we couldn't get it out since it was welded there from BTS. Awe well so we pulled the turbo, rocked the motor and got the stud in. Installed all 8 injectors, and had to clearance one of the hold downs. By 4AM we were buttoned up and went to bed. IIRC... took approximately 12 hours from time we popped the hood till the time it was ready to fire.
The next morning we finished Steve's truck and I left early to see the game but missed it anyway. Oh well.
So here's the recap:
Steve's truck: Got H11 Studs, 200cc Injectors and a contribution test.
Matts truck: Got broken down to send injectors off and a contribution test.
Jay's truck: Got a stealth stage 2 HPOS installed in his truck.
Pictures and video's to follow shortly.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 13 (permalink) Old 10-12-2008, 10:30 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Fall Brawl Prep = Success!
Elkton, Maryland
Marty is offline
post #3 of 13 (permalink) Old 10-12-2008, 10:33 PM Thread Starter
Busy Busy
Marty's Avatar
Elkton, Maryland
Marty is offline
post #4 of 13 (permalink) Old 10-12-2008, 10:34 PM
King Dingaling
TANK'S 250's Avatar
Nice job man.....glad things worked out for everybody....
When are you coming to do some work that I have planned for mine?
TANK'S 250 is offline
post #5 of 13 (permalink) Old 10-12-2008, 10:39 PM
Drink til she's cute
Thuglike's Avatar
Nice work Marty..see ya next weekend!!!
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #6 of 13 (permalink) Old 10-12-2008, 10:43 PM Thread Starter
Busy Busy
Marty's Avatar
Motor work or ...? I'm sure you got the suspension part worked out .
Thanks, it was all of us though. We worked incredibly well together!
Elkton, Maryland
Marty is offline
post #7 of 13 (permalink) Old 10-12-2008, 11:01 PM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
wow , you guys got alot accomplished in a short amount of time. Thats awesome
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #8 of 13 (permalink) Old 10-12-2008, 11:17 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
man.. you did keep busy over the weekend..you did a lot in a short time..looks good...hope mine goes this fast..but I'm doing mine alone....not many PSD hobbyist way up here
Ron's power stroke is offline
post #9 of 13 (permalink) Old 10-13-2008, 12:46 AM Thread Starter
Busy Busy
Marty's Avatar
Here's a compression test how to video I made this weekend.
Elkton, Maryland
Marty is offline
post #10 of 13 (permalink) Old 10-13-2008, 12:48 AM Thread Starter
Busy Busy
Marty's Avatar
I like driving to and from Matt's house... here's a nice lil video I made coming over the bridge at point of rocks... like the engine noise, scenery, and of course the tunes!
Elkton, Maryland
Marty is offline
