not sure what my next mod should be - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-11-2008, 01:08 AM Thread Starter
I'm building it more for pulling than racing
If i had a money tree I'd be all set, but i don't so the options are
option 1
stage 1 injectors, bigger fuel lines, bigger fuel pump, water/meth
if i go stage 2 I'll need heads studs, springs, are stage 1's worth it though?
option 2
bigger fuel lines, bigger fuel pump, water/meth, Detroit locker in the rear, traction bars
F-350 is offline
post #2 of 7 (permalink) Old 10-11-2008, 01:24 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Re: not sure what my next mod should be
You don't really need head studs until stage III's. If you plan to pull I would go with some hybrids have have your tuner tune them to your needs. You have more fuel when you want it later.
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #3 of 7 (permalink) Old 10-11-2008, 01:55 AM
Pulling sled for hire
ParkerFly's Avatar
You don't have to have studs/springs with Stage 2's. Put them in and be done. If you go too small you'll always regret it, and you can always tune down the bigger sticks like rr86 said.
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #4 of 7 (permalink) Old 10-12-2008, 02:53 AM
dzljon's Avatar
i put my injectors in with a factory pump and used it that way for over a year pulling power was good but even with little stage ones the smoke was horrible egts were high, i purchased a stage 1 stealth and found a tune on my chip that puts icp at 3100 psi at 10% throttle, that made all the difference before i dyno'd at 363 hp w/o pump and i would bet that i have at least 35 more with the pump and no smoke lower egts and pulling my 24' race trailer at 10000 lbs it 100% better fuel consuption unloaded is averaged at 18.5 over the last 6 tanks and loaded is 12 mpg but i think i can get better when i get new tunes from wildman.
point being if i could go back in time i would have purchased good big oil tunes and a pump first.
just my 2 cents
99.5 F250/ VGT 5.9 CR Cummins4 link front and rear air ride
dzljon is offline
post #5 of 7 (permalink) Old 10-12-2008, 07:11 PM
Village Idiot
southmike's Avatar
just as a side q
how is your suspension set up?
there are a few pullers on here that should have plenty of advice, some have stronger rigs then others but plenty of good info.
southmike is offline
post #6 of 7 (permalink) Old 10-13-2008, 04:04 PM
stroketeck's Avatar
cummins should be the next mod
stroketeck is offline
post #7 of 7 (permalink) Old 10-13-2008, 04:35 PM
Layson's Avatar
I don't think stage I's or II's are even worth it... Hybrids all the way... :)
Layson is offline
