Help Me Out Here - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 10-10-2008, 03:58 PM Thread Starter
Back to Civilian Life!!
MILFORD's Avatar
Help Me Out Here
Ok I put some stage IIs in my truck the other day and it would not start after putting everything back together. It started to pour fuel out of the tail pipe so I figured that one of the injectors did now seat right. I took out all of the injectors checked the O rings and the copper ring and they were all good. I proceeded to put it all back together and it still wont start. Now my Batteries are dead from trying to start it so much. Got that sitting on a charger. I still spits out a little bit of fuel but I think it is just excess from the night beffore that was still in there. The truck refuses to fire and spits fuel out of the tail pipe still. What could the problem be? FYI I dont have a chip for single shots in it yet should be here today.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #2 of 30 (permalink) Old 10-10-2008, 04:02 PM
All done now
Arisley's Avatar
Re: Help Me Out Here
Pull out your glow plugs and crank it over. Make sure all the fuel is out of the cylinders, don't want a hydrolock. Check your oil, make sure there is no fuel in there "bet there is though", if so change it (fuel makes oil thin and won't lube anything".
Have not heard of this since Andrew did it.
Not comparing you to Andrew by any means.
Arisley is offline
post #3 of 30 (permalink) Old 10-10-2008, 04:09 PM
Member
vapstroke's Avatar
lol any video?
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #4 of 30 (permalink) Old 10-10-2008, 04:11 PM Thread Starter
MILFORD's Avatar
I did both of those already. Everything was out of the cylinders and was turning freely. I checked the oil and it didnt smell like fuel was in it. HPOP reservoir is 1 inch from the top. I hooked it to a scanner and was not pulling any codes all the injectors got buzz tested and they were all fine. I dont know.
MILFORD is offline
post #5 of 30 (permalink) Old 10-10-2008, 04:12 PM Thread Starter
MILFORD's Avatar
Nope. It pissed out so much fuel I kinda laughed about it at first till I realized o $*it that means I cant drive my truck tonight
MILFORD is offline
post #6 of 30 (permalink) Old 10-10-2008, 04:28 PM
All done now
Arisley's Avatar
Just make sure everything is hooked up right. You probably just have a bunch of air in the lines. Hot batts, and patience.
Oh and please do have the video running if you see more fuel running out the tail pipe. Post it under Andrews name, we have been looking for that video.
Arisley is offline
post #7 of 30 (permalink) Old 10-10-2008, 04:35 PM Thread Starter
MILFORD's Avatar
. Ok. Any thoughts on what the fuel is coming from?
MILFORD is offline
post #8 of 30 (permalink) Old 10-10-2008, 04:46 PM
All done now
Arisley's Avatar
Probably did not have an injector seated correctly.
Arisley is offline
post #9 of 30 (permalink) Old 10-10-2008, 06:52 PM
00PSD1's Avatar
very funny Andy
2000 F250 EX LB 4x4 XLT
00PSD1 is offline
post #10 of 30 (permalink) Old 10-10-2008, 07:14 PM Thread Starter
MILFORD's Avatar
... Here we go
MILFORD is offline
