Just replaced up pipe donuts, Yum..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-10-2008, 02:02 PM Thread Starter
So I replaced the donuts on my up pipes yesterday.
The passenger side was blowing alot of soot and the drivers side was loose. Not as bad as I thought it would be.
I hope this helps out w/ my high EGTs.
I used the felpro SB chevy donuts instead of the stock donuts and covered them in anti seize. Then I tightened the piss out of them.
Is there any reason to tighten them again today? Will the donuts crush anymore, or am I good to go?
Also, is there a right way or wrong way to install the up pipes. I got them in place, and then put the lower bolts in to hold them. After that, I tightened down the donuts, then the lower bolts.
Does that sound right?
I'm going to dyno the truck tomorrow, so I wanted to fix the leaks first. I'm shooting for 400.
Thanks,
Sean
99 F350 CCLB
skav is offline
post #2 of 16 (permalink) Old 10-10-2008, 04:16 PM
HP Junky
Re: Just replaced up pipe donuts, Yum.....
I tried going the cheap route and used the 350 gasser donuts, I can't get them to seal. Ordered the factory ford donuts yesterday.
RockinJW is offline
post #3 of 16 (permalink) Old 10-10-2008, 04:27 PM
Busy Busy
Marty's Avatar
Finger tight on all of the bolts and then line the pipe up. Then tighten them down to spec.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #4 of 16 (permalink) Old 10-10-2008, 04:29 PM
All done now
Arisley's Avatar
Did you use the cheap donuts or the expensive ones. The cheapos crush easily. The expensive ones will not crush.
Arisley is offline
post #5 of 16 (permalink) Old 10-10-2008, 06:23 PM
HP Junky
They were Fel-Pros, cost $1.99 each
RockinJW is offline
post #6 of 16 (permalink) Old 10-10-2008, 08:24 PM Thread Starter
I have a set of ford donuts, but I was told that the felpro donuts were better, so I went with them instead. If it turns out that the stock donuts are better, I'm going to be pissed. Changing the up pipes isn't as easy as doing an oil change
I also heard that you can mill .0030 (30 thousandths) off the upper collars and get the stock donuts to crush a bit more.
Has anybody used the brass donuts from Bean?
99 F350 CCLB
skav is offline
post #7 of 16 (permalink) Old 10-10-2008, 10:41 PM
Pipewhiner's Avatar
I just bought the uprade kit from International..well wort the extra change and no more leaks
1999.5 Brugundy/Black CC 4x4 Dually BTS, IH DTA360 conversion completed
Pipewhiner is offline
post #8 of 16 (permalink) Old 10-10-2008, 10:48 PM
yea buddy!
Stites02psd's Avatar
i got the brass ones and the wrked great no leaks or nothin crazy
02 reg cab dually, stage 2's, Garrett bb,air dog 100,fancy new up pipes, aeromotive 1000, some cool lookin gauges, kewl lookin chrome flashy tip, 423.9/900 at the beaners dyno
1991 f-250, 15mpg
1994 2500, built 215,cam.. worst mistake of my life....wish i had my ford back
MOTIVATED BY THE HATERS
Stites02psd is offline
post #9 of 16 (permalink) Old 10-12-2008, 05:33 AM Thread Starter
What's the upgrade kit?
Will it work w/ the hypermax up pipes?
99 F350 CCLB
skav is offline
post #10 of 16 (permalink) Old 10-12-2008, 07:28 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
No it won't, just factory stuff.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
