Surging question D66 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 10-10-2008, 02:28 AM Thread Starter
NVJAY775's Avatar
Hey guys. I just upgraded my D66 with a cryo bearing and a 1.15 exhaust housing. Happy with the drop in egts. But still have some surging going on. Unhooked from a trailer I only notice it a little in 3rd, but in 4th at 2000 rpms and up at half throttle it gets kinda bad. When hooked to a 3000 lb trailer it gets worse from 2nd gear on. (My heaviest trailer is 9000 lbs) Mostly noticeable at half to 3/4 throttle. When at full throttle it is still there, but isn't nearly as bad. I can't hear it, but can see it on the gauge. Any thoughts? A buddie of mine is running the same setup with a 38r with no surge. And I am still smokin a bit and am considering more air, but don't know what direction to go yet. I'm at 4,300 ft and am boosting 32psi.
Thanks in advance guys!
Silver 00 4x4 ex cab lb
305 70 16's
DIY Tymar
5" stack
Modded H2E from ctperformanceinc.com
180cc AA's
DP Tuner F5
Full Jimmy Converse trans / converter
6.0 trans cooler
NVJAY775 is offline
post #2 of 26 (permalink) Old 10-10-2008, 02:33 AM
Oooo, White Lightning !
Dieselboy's Avatar
Re: Surging question D66
Go to an H2E setup......
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #3 of 26 (permalink) Old 10-10-2008, 04:21 AM
Or a 38r or PDR or HX50 anything that is better sized to your application. The D66 uses a stock cartridge IIRC so you are right at the limit for what it was designed for.
69W900A is offline
post #4 of 26 (permalink) Old 10-10-2008, 04:24 PM
Wheelie Dude
bean's Avatar
Send a message via AIM to bean
PDR and 38 will move no more air then the D66. The next step up from those turbos is a modded h2e.
Not sure why you are getting surge especially with a 1:15 housing, I have had maby one other complaint about slight surge with a 1.0 housing, 1:15 should not surge at all. I am thinking there is a problem with tuning with fueling levels at part throttle. Not enough fuel will cause it to not be able to maintain drive pressure when compared to boost at that throttle position.
Smokin' Hot Hooker- 2002 F350 Dually 4x4 6spd- 5.9 CR-
BDP Drag Truck- 81 C10-5.9CR, BTS 4R, Goes Fast
Beans Diesel Performance
bean is offline
post #5 of 26 (permalink) Old 10-10-2008, 04:29 PM
Cummins Power
mech2161's Avatar
4300 ft may be the issue with tuning?
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #6 of 26 (permalink) Old 10-11-2008, 02:03 AM Thread Starter
NVJAY775's Avatar
I'll give Jody a call Monday and see if he can do some fuel tweaking, as requested by Bean. Thanks to Bean and Adam for the call today. I'll post back with results. It may take a while. I need to get the module and cable to download the new tune to my tuner. I'll probably need a hall pass from the wife on that. She hates my truck...
Thanks for all the input guys.
I'll check back daily.
Jay
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
post #7 of 26 (permalink) Old 10-11-2008, 02:07 AM
2nd class citizen
1snotrocket's Avatar
dp tuner will be closed till 10-19-08. they will open on the 20th
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #8 of 26 (permalink) Old 11-07-2008, 04:41 AM Thread Starter
NVJAY775's Avatar
Thanks guys. I'm on stand by to stand by. Modded H2E? H2E kit w/ different turbo maybe?
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
post #9 of 26 (permalink) Old 11-07-2008, 04:54 AM
Sponsor
airflo71's Avatar
The turbo isn't the problem, as stated above it is the fuel. Too many times when a surge condition is found, it can be traced back to the tuning. Yeah if a turbo housing is fitted incorrectly that is one thing but a 1.15 house, nope.
airflo71 is offline
post #10 of 26 (permalink) Old 11-17-2008, 02:16 AM Thread Starter
NVJAY775's Avatar
Well... Come to find out. The turbo is awesome, but it doesn't work on my truck.
I'm on a budget, so I am going to limp it til I can get a set-up that works. Kind of hard when I tow every day. Hope she'll last.
Thinkin H2E modded or something like it. Not 38R. But something that will bolt up to the H2E turbo mount.
The surge gets better when the tuner is turned down BTW. Fuel is badd evidently. So it is turned down to stock.
Any better turbo thoughts, that will mount up to the H2E set-up?
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
