hx55 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-10-2008, 01:27 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
hx55
Has any one ever ran a 55? I was thinking of it for my new 2nd stage and I believe a wastegated housing is avaliable for it too which is a plus. Any info would be appreciated.
Thanks
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 7 (permalink) Old 10-10-2008, 02:05 AM
Re: hx55
House has one. It's similar in size to an H2E. It has a regular T4 or T6 flange.
69W900A is offline
post #3 of 7 (permalink) Old 10-10-2008, 02:12 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: hx55
Yea I couldnt remember if his was a 50 or 55. I was looking at one that just went for 102 on ebay. I guess I should have bought it I just dont know how well it will light in a twin setup.
Tow Mule
post #4 of 7 (permalink) Old 10-10-2008, 04:24 AM
Re: hx55
The 55 is a little bigger than an "stock" H2E. Depends on what housings you get as well. Most of the 50's and 55's you find cheap are spec'd for a mid-range engine so the turbine is probably gonna be bigger than you'd want for the high pressure turbo. You'd have to look at the exact specs for the one you are looking at.
69W900A is offline
post #5 of 7 (permalink) Old 10-10-2008, 10:35 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: hx55
Thanks Ill have to find out the exact specs. If it means anything it a a 55w. I believe it was probably a mid-range specd turbo as it has the big t6 flanged housing on it.
Tow Mule
post #6 of 7 (permalink) Old 10-10-2008, 10:54 PM
02stroke'n's Avatar
Re: hx55
i know of one for sale if interested...
02 250 xlt
200cc/30% hybrids from Rosewood Diesel,TW tunes,TN BB w/new oulet and non-ebpv ped,built auto by Coal Train diesel performance,DI's RR,Airdog 150,AutoMeter ultra-lite-egt,boost,trans,fuel,S/B intake,HPX,6in flat tops
needed-studs,rods,springs,p-rods-HPOP
02stroke'n is offline
post #7 of 7 (permalink) Old 10-11-2008, 01:20 PM
stroketeck's Avatar
Re: hx55
i run a hx55 with the twins on my 4bt, as far as housings i have only found 1 through holeset?
stroketeck is offline
