FASS 150/180 FILTERS Need Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-09-2008, 11:53 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Any body know the part number for the two filters. the main filter and the water trap. Blowing 30 amp fuses. Hope it's bad filters.
I need a number oreilly can cross.
PTSUPERD is offline
post #2 of 16 (permalink) Old 10-10-2008, 12:35 AM
Member
vapstroke's Avatar
Re: FASS 150/180 FILTERS Need Help
The water seperator is a Fleetguard fs1023. I think the other one is a HF6604 not positive on this one though.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #3 of 16 (permalink) Old 10-10-2008, 01:11 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
My guess is the pump motor is going out like mine did. I kept blowing the 30 amp fuse on the relays wiring harness. Finally determined it was the motor.
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #4 of 16 (permalink) Old 10-10-2008, 01:16 AM
Member
vapstroke's Avatar
Is it wired with a relay straight off the battery? How did you set it up with the regulated return? Did you use a ball valve? How many miles have you gotten out of it?
post #5 of 16 (permalink) Old 10-10-2008, 01:30 AM
Starting Over
kainers's Avatar
napa 1202 for the filter.The separator I don't have but if you search my user name you will find the post I made on filters.The water separator that napa has you don't want to use but for emergencies only.
kainers is offline
post #6 of 16 (permalink) Old 10-10-2008, 01:36 AM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
get an RMA that pump is toast. I've gone through one and number 2 is on it's way out. What does it sound like before the fuse blows. Does it start to wine irregularly? If so son;t even waist you time changing the filters.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #7 of 16 (permalink) Old 10-10-2008, 01:42 AM
Supercharged
Yeah, once I get the truck running again. I will worry about my FASS again on road trips I am going to make it so my stock pump fits back in the system quickly.
Oil- Swamps Gen-3
Fuel - B-codes
post #8 of 16 (permalink) Old 10-10-2008, 02:22 AM Thread Starter
Banning Smut
PTSUPERD's Avatar
I replace the fuse....and it makes a grinding sound for about 5 seconds and then the fuse pops.
So frustrated. Been busting my azz at work after the storm for the past 3 weeks. Too tired to even jack with it.
Guess I'll be drivin the beater to Houston tommorow. Just had the truck detailed today too.
2 yrs with this pump and no real issues.
PTSUPERD is offline
post #9 of 16 (permalink) Old 10-10-2008, 02:50 AM
Member
vapstroke's Avatar
yep time for a new pump.
post #10 of 16 (permalink) Old 10-10-2008, 03:37 AM
DILLIGAFF
Send a message via AIM to Redfish
But how will you get the PSN barf cart there???????
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
