Anybody have a fumoto valve leak? I believe mine is. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-09-2008, 11:58 AM Thread Starter
I have had some very light oil film around the back of the pan. I thought it was the rear main, but it starts from the back of the fumoto and extends to the rear of the pan. I saw a small drip on the fumoto yesterday. Anybody have one of these leak? Also, does the shop vac on the oil fill hole work to keep the oil in while I change it out. I have a lot of clean synthetic oil in there that I don't want to part with. Thanks
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #2 of 16 (permalink) Old 10-09-2008, 01:01 PM
OEM Moderator
Tom S's Avatar
Re: Anybody have a fumoto valve leak? I believe mine is.
The shop vac trick works just fine to swap out plugs. I think you would be the first report I have read of one leaking.
Tom
Tom S is offline
post #3 of 16 (permalink) Old 10-09-2008, 01:54 PM
Martin #6's Avatar
I had one leak on me on our Volvo XC, but no problems with the one on the PSD.
2008 F-250 Lariat CC 4x4. EPA stock.
Martin #6 is offline
post #4 of 16 (permalink) Old 10-09-2008, 06:45 PM
Hoosier daddy!
Ramblin'_Man's Avatar
Be sure that what you're seeing is not oil dripping down the pass. side of the block and then down onto the pan. I had the very same oil residue you are talking about, but it came from the turbo pedistal(I believe) and dripped down the pass. side of the block and eventually onto the pan and down around the drain valve. In my case, the reason that the oil ended up around my fumoto was because at night where I park, the front of the truck is lower than the rear...
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #5 of 16 (permalink) Old 10-09-2008, 06:50 PM
Orezona's Avatar
My 1st one leaked. Bob (DieselSite) sent me a new no questions asked. Bob said it was the only one he'd sold that leaked.
Orezona is offline
post #6 of 16 (permalink) Old 10-09-2008, 07:03 PM Thread Starter
I think it is leaking from around the threads. There is an oil residue around the entire valve, where it threads in. The oil residue then extends from the valve to the back of the pan. Except for immediately around the valve, in front of the valve is bone dry. Is there a gasket around the thread area?
post #7 of 16 (permalink) Old 10-09-2008, 07:09 PM
Orezona's Avatar
It should have came with a plastic washer. I tried using a brass one and it didn't like it.
Orezona is offline
post #8 of 16 (permalink) Old 10-09-2008, 09:39 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
im sorry guys, but WTF is a fumoto valve?????
CCLB with some stuff done .....
BigRed97 is offline
post #9 of 16 (permalink) Old 10-09-2008, 09:43 PM
Orezona's Avatar
http://www.dieselsite.com/index.asp?...S&Category=451
Orezona is offline
post #10 of 16 (permalink) Old 10-10-2008, 12:44 AM Thread Starter
Yeah, I have a washer of some sort on there. It looks like it is coming from out of there.
