Any one know anythign about these? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-08-2008, 08:19 PM Thread Starter
badlogin's Avatar
I want to do the CCV mod. I found this and didn't know if it would work for our kind of trucks? Also what is the CFM required for proper breathing. http://www.maesco.com/products/racor...ccv_intro.html
99.5 F350 cc PSD. BD Dyno 318/748. 4" lift, Fox Shocks 35" BFG AT's and Weld wheels, ATS 4R100 stage4 trans and converter, ATS compressor housing. EBP delete fix, Over boost fix, TS 4 position chip 50 75 100 and 140 hp, Hypermax 5" exhaust, three gauge pillar set tranny temp pyro and boost. Extreme Duty air cleaner
badlogin is offline
post #2 of 7 (permalink) Old 10-09-2008, 03:05 AM
What else?
smokyred's Avatar
Re: Any one know anythign about these?
BD Power makes a CCV reroute system now, and it looks like one of those canisters is what comes in the kit. I bet you can build your own copy for alot less than BD's kit.
Dave
smokyred is offline
post #3 of 7 (permalink) Old 10-09-2008, 12:06 PM
casper7.3's Avatar
check out the sticky for guzzle's mods thats what i did, i got about 25 bucks in it. works great!
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
casper7.3 is offline
post #4 of 7 (permalink) Old 10-09-2008, 01:13 PM
Racor also makes the CCV3550 that is a direct bolt on for the 7.3Ls. Its a little pricey at ~$370 though.
Racor CCV 3550-FRD-02
2002 F250SD SC LB 4x4, AFE Stage 2 PG7, MBRP T304 Cool Duals, BD Exhaust Brake, WW, ATS Housing, FTVB, TM Wastegate Controller, Brite Box, CCV Mod, Coolant Filter, 9 Isspro Performax gauges.
To-Do: Air-Lift Air Bags install
90ranajo is offline
post #5 of 7 (permalink) Old 10-09-2008, 09:32 PM
SmokeWithEveryStroke's Avatar
Ran mine at a 45 into the exhaust by the t-case cost about $12 and a half hour or my time.
99 ExCab Sb 6spd pulling truck (PULL-N-PRAY)
08 cclb
SmokeWithEveryStroke is offline
post #6 of 7 (permalink) Old 10-10-2008, 11:08 AM
JimTJr's Avatar
Make one out of PCV pipe, fittings and scrubby pads from the kitchen. Put a drain on the bottom. 15 bucks, and your done I bet. I have not done one yet, still venting to the atmosphere... (Bad, I know,, tree huggers....)
*48* Jim T. 2011 F-350 Lariat, CC, LB, SRW. White Platinum Metallic Tricoat. Black leather seats, I probably wont have*PMS,, with this one, at least no major attacks of it!
JimTJr is offline
post #7 of 7 (permalink) Old 10-11-2008, 12:44 PM
HarleyEdition78412's Avatar
Diesel Innovations sells the same Racor setup.
Current- 2006 Harley Davidson Edition F250 6.0L w/a "BUILT" engine, Unfortunately mis-assembled and installed by CenTex Diesel and a NAPD Heavy Hauler RACE SERIES Transmission
Previous- 2001 Platinum Edition F250 7.3L
SCT LW and FICM tuning-
Regulated Return fuel kits-
ENOUGH SAID
HarleyEdition78412 is offline
