Head Stud Install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 10-06-2008, 11:27 PM Thread Starter
Edward Scissorhand WanaB
Bushwakd's Avatar
Head Stud Install
Is it possible to install head studs while the motor is in the truck?
As in, pull one stock stud, install a performance stud?
Who all has done it and was there any tricks to doing it?
I know it will be a pain in the a$$ but can it be done?
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #2 of 26 (permalink) Old 10-06-2008, 11:43 PM
Starting Over
kainers's Avatar
Re: Head Stud Install
Yes it is easy actually with help.You have to pull the nuts off the motor mts there is 4 of them and the two on the tranny x member.Jack the motor each way to make room.You will also have to pull the cover off the AC box<-Lots of little mofo bolts and you will have xtra upon reassembly.
kainers is offline
post #3 of 26 (permalink) Old 10-06-2008, 11:54 PM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
They really aren't that bad to install with the motor in the truck. I did mine with the motor in and helped with Kainers install. If you keep busy, it is a day job.
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #4 of 26 (permalink) Old 10-07-2008, 12:48 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
I Pull the cab off, way easy then.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #5 of 26 (permalink) Old 10-07-2008, 01:08 AM
Layson's Avatar
It took me about 10 hours for springs and studs... I would do it over again...
Layson is offline
post #6 of 26 (permalink) Old 10-07-2008, 02:02 AM
Supercharged
-Michael
I think I could have the studs in the hard side head done before you got the cab off..
Do them with the engine in the truck.
Oil- Swamps Gen-3
Fuel - B-codes
post #7 of 26 (permalink) Old 10-07-2008, 02:18 AM
What else?
smokyred's Avatar
But if you're doing studs, springs, injectors, turbo, etc. all in one shot, pulling the cab can save time in the long run, as well as my back and knees!
Dave
smokyred is offline
post #8 of 26 (permalink) Old 10-07-2008, 02:20 AM
matthewd11's Avatar
It took me 2 days to do injectors head studs and valve springs...that was in a driveway, without a lift, and no air tools.
matthewd11 is offline
post #9 of 26 (permalink) Old 10-07-2008, 02:22 AM
What else?
smokyred's Avatar
And how did you feel after the job was done? You should make friends with someone who owns a shop!
Dave
smokyred is offline
post #10 of 26 (permalink) Old 10-07-2008, 02:27 AM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Well I think Steve is looking for the procedure of the least resistance. I think the hole in the valance to get the last stud in works the best.
OK Ok I'm looking for the procedure to do it without pulling the cab or dorking with the motor. It's going to be half in my garage and i don't want to wrestle the motor and tranny if I don't have 2.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
