ARP Head Studs Torque Info - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 10-06-2008, 12:41 AM Thread Starter
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
What are the studs suppose to be torque at (ft lbs) if i remove one bolt and install one stud at a time. Is there a sequence?
Head Gaskets are alright and there isnt any signs of hg failure of any kind. IMO theres no sense in pulling the heads if the gaskets are ok.
Im doing upgrades some more upgrades which include; bigger injectors, turbo, head studs, valve springs, pushrods. These are all gonna be done at the same time probably Tuesday or Wednesday.
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #2 of 14 (permalink) Old 10-06-2008, 12:57 AM
matthewd11's Avatar
Re: ARP Head Studs Torque Info
You're gonna put more power on that stock bottom end???
matthewd11 is offline
post #3 of 14 (permalink) Old 10-06-2008, 12:58 AM
Layson's Avatar
I think the first round you have to go to 90 to match the stock torque. (whatever sequence you want)
Once you have them all replaced start torquing them down in stages.... I think I went to 125 next. There is a specific torque sequence for that(I think you start on the outside bottom row and work your way up to the top). Then I loosened one up at a time and retorqued to 135.. then I loosened each one up and retorqued to 140. Then went back and loosened each one and retorqed it back to 140...
ARP says to loosen them up a few times and re torque them because they will stretch. I have read alot of guys won't do this. But I did...
I have heard of guys going to 135 and 140 for the final torque.
Layson is offline
post #4 of 14 (permalink) Old 10-06-2008, 01:05 AM
matthewd11's Avatar
FYI i did 140 on my final torque and used the sequence layson described.
post #5 of 14 (permalink) Old 10-06-2008, 01:13 AM Thread Starter
10.61 @ 128 MPH
Yep. The stock bottom end will be just fine
Thanks for the info guys.
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Swamps Diesel
post #6 of 14 (permalink) Old 10-06-2008, 01:42 AM
moore20017.3's Avatar
I made a kick a$$ valve spring tool if you need to use it I'll send it your way. You might have to do some motor rocking for the studs anyway. But if you need it I am going to Fedex first thin in the morning to send my expenses.
I should try to sneak in the bill for springs and prods, lol.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #7 of 14 (permalink) Old 10-06-2008, 01:49 AM Thread Starter
10.61 @ 128 MPH
Thanks, but i am going to lift the cab. Should be a lot easier. Rave, the owner of twisted diesel is going to help me out. Hes done numerous head jobs on 6.0's. He said the cab will be cake on my truck and would probably take couple of hours to lift off the frame.
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Swamps Diesel
post #8 of 14 (permalink) Old 10-06-2008, 01:51 AM
Fat Kids Rule!
House's Avatar
Send a message via AIM to House
140 here
Joe "House" Kupferschmid
1995 F250 7.3 2.6 zf6 Puller
2006 Chevy 3500 CC DRW LBZ, Tow Slut
SOLD:2000 F350 harvester of sorrow
House is offline
post #9 of 14 (permalink) Old 10-06-2008, 01:51 AM
Damn good idea. That will save some sore knees and back. Lucky man
post #10 of 14 (permalink) Old 10-06-2008, 02:00 AM
Got Whistle?
crack_7.3's Avatar
im interested to see how lifting the cab goes as I am going to do studs springs injectors very soon if I get time.
08 F350 Lariat
Blacked
IDP tuned SCT
crack_7.3 is offline
