6.0 inercooler?????????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-04-2008, 03:39 AM Thread Starter
99redf350's Avatar
How big of a diff. does the 6.0 inercooler make?????
late 99 f350, guages, mbrp, cold air, SWAMPS 300/200 hybrids, gen 3, fuel lab, fuel regulator, gt42r and of course a ts tuner by swamps , currently broke
99redf350 is offline
post #2 of 6 (permalink) Old 10-04-2008, 03:47 AM
SKWERL's Avatar
Re: 6.0 inercooler??????????
A big one, Id go with an after market one to get the aluminum end tanks.
SKWERL is offline
post #3 of 6 (permalink) Old 10-04-2008, 02:46 PM
Village Idiot
southmike's Avatar
well all depends, some say 50° drop maybe more.
it will help some but not as radical as an full bore aftermarket version
...course the 6.0 is 1~300 VS 900~1300 bucks for a spearco , DI , or ATS etc..
southmike is offline
post #4 of 6 (permalink) Old 10-04-2008, 02:49 PM Thread Starter
99redf350's Avatar
Thanks mike
post #5 of 6 (permalink) Old 10-04-2008, 06:48 PM
It's not a bad mod for the money IMO. I put one on the '01. It mounts right up, but you'll need to modify the IC piping a bit (except for the '03 models, as I believe even the 7.3s already have the bigger cooler). There should be a write-up with pics floating around here or on the other site.
It does have the plastic end-tanks, so keep that in mind. This shouldn't be an issue unless you're making some relatively large boost numbers (I've pushed 40-45lbs without any issues).
Hope this helps.
-Brent
TXstroker01 is offline
post #6 of 6 (permalink) Old 10-07-2008, 03:33 AM
Village Idiot
southmike's Avatar
joe might be a good one to ask
look for a user cspid I believe joe did the 6.0 mod and tows with it.
he def has the gauges to tell the diff.
I plan on doing it some day if I come across a deal on a 6.0 ic
