valve spring changeout? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 10-04-2008, 02:42 AM Thread Starter
moore20017.3's Avatar
How did y'all get passenger springs changed? The tool I borrowed worked great on the driver side except for the intake on #8. I am going to build a cam over lever device that bolts to the rocker arm holes i guess to do the rest.
Any suggestions?
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #2 of 15 (permalink) Old 10-04-2008, 12:38 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: valve spring changeout?
i was told un bolt the motor mount on driver side and jack it up on that side..it will twist the motor lowering that side so the tool will fit in under there for #8
Ron's power stroke is offline
post #3 of 15 (permalink) Old 10-04-2008, 02:12 PM
Plays with Motors
Machinist's Avatar
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #4 of 15 (permalink) Old 10-04-2008, 04:23 PM
Hey, that one even comes with spare parts!!!
69W900A is offline
post #5 of 15 (permalink) Old 10-05-2008, 01:48 AM
What else?
smokyred's Avatar
I have that exact spring compressor sitting right here, lol.
Dave
smokyred is offline
post #6 of 15 (permalink) Old 10-05-2008, 05:24 AM
Layson's Avatar
Originally Posted by Machinist View Post
If you use this you have to jack up the motor to get it to fit. Plus you will have to remove the handle on it and use a socket. FORD makes one that bolts right down to the rocker arms and fits without moving anything...
that is why I was asking you if you were installing headstuds... since I figured you were jacking the motor up anyway.. you might as well..
Layson is offline
post #7 of 15 (permalink) Old 10-05-2008, 04:16 PM
<- Sums it up
strokin_early_99's Avatar
That is the tool I used and the method I used to do the springs and head studs. That spring tool uses a 5/8" socket or ratcheting end wrench, I prefer the ratcheting end wrench myself. On the passanger side I took the evaporator cover off.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #8 of 15 (permalink) Old 10-05-2008, 10:07 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
If you haven't yet, try taking the A/C box apart like mentioned above. Its only like 8 or 10 screws I think
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #9 of 15 (permalink) Old 10-05-2008, 11:28 PM
Layson's Avatar
You have to take the AC cover off to do it... there still may be one that conflicts with the back part of the box.
there are a lot of those screws.. I still ended up with two I couldn't find homes for after I was finished...
Layson is offline
post #10 of 15 (permalink) Old 10-06-2008, 12:10 AM
You are just improving on the engineers design and not reusing those spare parts. Besides, with the weight reduction you'll go faster and get better fuel mileage
69W900A is offline
