Torque specs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-03-2008, 09:49 PM Thread Starter
Subject Matter Expert
PowerstrokeJunkie's Avatar
Torque specs
I need to know the torque specs on the WOP main girdle studs, crower connecting rods, and H-11 head studs with fire rings. Are fire rings reversable, and reusable (both, im guessing is yes). I didnt look too closely but as far as i could tell it could go in either way. Also as far as the headgaskets, no material stuck to either the head or the block, should i still get new ones to control the coolant? They have been squished once but they still look in great condition. If i need a new set of gaskets can i get them from WOP or anywhere else?
Stock
PowerstrokeJunkie is offline
post #2 of 11 (permalink) Old 10-04-2008, 01:06 AM
diesel rocket scientist
bosco443's Avatar
Re: Torque specs
head gaskets are like condoms. new cometics are your friend. e-bay $260, feel the love. just my 2 cents> B.
99 f250
Lycoming/Westinghouse conversion in progress
bosco443 is offline
post #3 of 11 (permalink) Old 10-04-2008, 04:42 AM Thread Starter
Re: Torque specs
Do you always use a head gasket
Stock
post #4 of 11 (permalink) Old 10-04-2008, 04:47 AM
All done now
Arisley's Avatar
Re: Torque specs
Never resquish a head gasket (unless of course you can turn it inside out)
OK just kidding on the inside out part, but never, ever, reuse a head gasket.
Arisley is offline
post #5 of 11 (permalink) Old 10-04-2008, 04:49 AM Thread Starter
Re: Torque specs
Can i buy a new set from wide open?
Stock
post #6 of 11 (permalink) Old 10-04-2008, 04:53 AM
All done now
Arisley's Avatar
Re: Torque specs
Bet you can. But might want to call to be sure.
Arisley is offline
post #7 of 11 (permalink) Old 10-06-2008, 11:10 AM Thread Starter
Re: Torque specs
Bump.... Crower rod bolt torque, main stud torque, H-11?
Stock
post #8 of 11 (permalink) Old 10-06-2008, 02:11 PM
cota's Avatar
Re: Torque specs
On the girdle I was told the short studs are 98ftlbs and the long studs are 105ftlbs. Best to give them a call to be shure. Let me know if I'm correct.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #9 of 11 (permalink) Old 10-06-2008, 04:51 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: Torque specs
fire rings are one time use
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #10 of 11 (permalink) Old 10-06-2008, 06:16 PM
you want some of this?
smorris's Avatar
Re: Torque specs
Unless you got cometics.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
