injector help. can i have my cake and eat it too? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 10-03-2008, 09:47 PM Thread Starter
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
early 99 and I want a good 400+ HP but want to tow a lot to.. can this be done with a 160 cc single shot while keeping EGT's in check..I have a stock IC and a 99.5 stock turbo and a 17 HPOP.. PCM up grade and tuning will be done with injector swap as well as a moded 140 IDM....van turbo or maybe a BB turbo is in the plans at a later date..but can only afford the injectors right now...also will my stock 120 cc injectors be excepted as cores?? thanks guy's
Ron's power stroke is offline
post #2 of 19 (permalink) Old 10-03-2008, 09:56 PM
OEM Moderator
Tom S's Avatar
Re: injector help. can i have my cake and eat it too?
I think 400plus HP is a little lofty with 160cc injectors unless they have modded nozzles.
Tom S is offline
post #3 of 19 (permalink) Old 10-03-2008, 09:57 PM Thread Starter
thanks for the reply
i was looking at these from Beans
http://www.beansdieselperformance.co...e/prod_15.html
or would the 175/146 from swamps be better??second one down in this link
http://swampsdiesel.com/
what would you recommend ??
post #4 of 19 (permalink) Old 10-03-2008, 11:17 PM
Crusty old Bastich
3-StarJ.R.'s Avatar
Bean/Casserly stage two's (160cc) with the correct supporting mods will easily get you to 400+. (See sig.) I towed medium heavy today in my 406 hp daily driver burn, 24 ft inclosed trailer around 10,000 lbs), about 400 miles and I had forgotten how good the combo of these two's and Beans d-66 pull a rig!! This is the first long pull I have made since I installed the Caltrac suspension system and with a heavy tag trailer they made it fell like I was pulling an unloaded gooseneck!! I'm one happy camper!!
A turbo upgrade, the correct fuel system and Casserly's two's are a sweet towing set-up.....I'm thinking about upgrading injectors, pm me about mine if you are interested....
Jim
96 CC 2wd Dually
BDP engine build
BDP D-66
BDP/Casserly Hybrids
BDP twin pump fuel system
Hypermax Rods
Caltracs
Detroit locker
FactoryTech tranny
3-StarJ.R. is offline
post #5 of 19 (permalink) Old 10-03-2008, 11:55 PM Thread Starter
is this your truck with them mods in you sig?? i like,,,
post #6 of 19 (permalink) Old 10-04-2008, 12:04 AM
Crusty old Bastich
3-StarJ.R.'s Avatar
Yep, that's my ol wide butted obs. Here is under the hood...
Jim
96 CC 2wd Dually
BDP engine build
BDP D-66
Hypermax Rods
Caltracs
Detroit locker
FactoryTech tranny
post #7 of 19 (permalink) Old 10-04-2008, 12:10 AM Thread Starter
damn that looks sweet... where did you get the chrome spider??? is that a 01 motor stuffed in there?? or is it the OBS rebuilt in 01??
post #8 of 19 (permalink) Old 10-04-2008, 01:19 AM
Crusty old Bastich
3-StarJ.R.'s Avatar
Ron, Thanks for the compliment! That is a stock early '99 spider that I slicked up....
the tubes are welded up combo pieces of stock SD and 6.0 tubes by my good friend "Sniper on high." I buffed them down and found some high temp clear coat for the finish on all three pieces.
Bean built me an awesome stock motor, (except for balancing the bottom, 910 springs and studs), in Jan. of last year after I windowed the block by floating the valves one to many times and running tuning other than what I run now....
Jim
96 CC 2wd Dually
BDP engine build
BDP D-66
Hypermax Rods
Caltracs
Detroit locker
FactoryTech tranny
post #9 of 19 (permalink) Old 10-04-2008, 01:58 AM
Banned
I made right at 430rwhp with bone stock nozzles. I could have towed at WOT and stayed cool if not for the rest of the driveline suffering catastrophic failure, as it eventually did.
I believe I was injecting at maximum of 180cc per 1000 shots. Maybe less.
Stock nozzles will make 400hp, but it takes some doing. And they will be the most behaved when towing of any nozzle.
Charles is offline
post #10 of 19 (permalink) Old 10-04-2008, 02:03 AM
99redf350's Avatar
i have swamp inj and i love them they are a 215/220 though
late 99 f350, guages, mbrp, cold air, SWAMPS 300/200 hybrids, gen 3, fuel lab, fuel regulator, gt42r and of course a ts tuner by swamps , currently broke
99redf350 is offline
