38R install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-03-2008, 09:11 PM Thread Starter
godofdew11's Avatar
Send a message via AIM to godofdew11
38R install
So after a couple tribulations that come with taking apart the stock exhaust fro the first time in the trucks life, its on and in. My first time pulling any turbo so i think it went relatively smooth. Now that its in though there seems to be some issue, i can only hit 15# of boost (20-22 with stock) and my EGTs are a lot higher then stock. Is there a way to check if it is oiling properly? this is my major concern Ive never seen it be an issue before but it would be catastrophic if it wasn't. don't see any exhaust leaks, haven't really checked for boost leaks, could it be a waste gate issue?
thanks for the help
-Don
'03 F-350 SC LB, 4x4 7.3, loaded, 3.5" DP to 4" Ex, tymar intake, 38r, strobes and LEDs galore. windshield mount 3 gaude pod,Gearhead toonz,BTS VB, 2.5" leveing kit. Toyo 315s. Last of the 7.3's
godofdew11 is offline
post #2 of 12 (permalink) Old 10-03-2008, 09:18 PM
<----Colin Banks
mattymx's Avatar
Re: 38R install
Make a boost leak tool and test for leaks. Could also be leaking from the up pipes.
mattymx is offline
post #3 of 12 (permalink) Old 10-03-2008, 09:30 PM
Proud PSN Sponsor
Deputydog's Avatar
Re: 38R install
You have classic symptoms of a boost leak.. I would suggest taking a peek at the clamp at the back of the turbo.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #4 of 12 (permalink) Old 10-03-2008, 09:36 PM
Re: 38R install
Make sure the oring from compressor outlet to manifold is in place.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #5 of 12 (permalink) Old 10-03-2008, 09:40 PM
Haulin' Iron
superih's Avatar
Re: 38R install
Probably a boost leak.
Check the waste gate though. Looks like you are only running a chip so you will be able to tighten the waste gate way up. The waste gates are not always set correctly from Garrett. I am running a Banks Big Head actuator (which is alot stiffer than stock) I am supposed to set the actuator 6 turns in, I went 8 to make sure it is staying closed and can build 32 psi.
Once you get it figured out you will like it.
'99 F-350 CC SB Lariat 4x4 Auto -DI chip-GTP38R-BPV delete-Zoodad-Suncoast tugger trans-6.0 trans cooler-Powerstop brakes-CCV-Gauges-Exhaust-AIS Intake-Kenwood sounds-
-Traveling the Earth 300 ft at a time-
superih is offline
post #6 of 12 (permalink) Old 10-03-2008, 09:58 PM Thread Starter
godofdew11's Avatar
Re: 38R install
Disconnected the waste gate and went for a drive no change, im pretty sure i have a boost leak i think i can hear it too, i did switch te oring over to the compressor outlet, i also put in bellowed uppipes with the install, and i see no soot on any exhaust connections ofr firewall so i THINK my exhaust is tight. how does one make a boost leak tool. deputy which clamp are you speaking of? the collector to the turbine?
-Don
post #7 of 12 (permalink) Old 10-04-2008, 01:14 AM
OEM Moderator
Tom S's Avatar
Tom S is offline
post #8 of 12 (permalink) Old 10-04-2008, 01:43 AM
<----Colin Banks
mattymx's Avatar
Re: 38R install
Originally Posted by Tom S View Post
For another idea. This is mine. About $20 to make.
mattymx is offline
post #9 of 12 (permalink) Old 10-04-2008, 05:08 AM
Canadian Powerstroker!
Oilfield_Digger's Avatar
Re: 38R install
I made one identical to Mattymx's and it worked great, cost like $15 and I had a gauge hanging around, mine was Y-pipe rubbers i bent them a bit when i installed the turbo, and it put tiny cuts in the hoses, had to get new ones. But all is good now.
03 7.3L F-350 Lariat FX4 CC LB
Mods: TN BB Turbo, NADP Heavy Hauler Tranny, DP F-5, Quad Pod w/ Autometer Phantom II's, AFE II PG7, AFE 409 SS 4" Exhaust, CCV, HPX, Non-EBPV & HFO, 95 Gal Aux tank/tool box, ITP OBA.
Oilfield_Digger is offline
post #10 of 12 (permalink) Old 10-04-2008, 01:32 PM Thread Starter
godofdew11's Avatar
Re: 38R install
hmm i bent teh crap out of a couple of them couldn't see any other way to get them where they belonged. what do new boots run from ford?and or napa? maybe i should just do hte 4 spider boots new and be done with it or at least the intake plelum ones.
Thanks for the help guys
-Don
