Just got my dptuner - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 10-03-2008, 02:12 AM Thread Starter
klipz's Avatar
Exclamation Just got my dptuner
I recieved the tuner and installed it as the directions instructed me to. The truck will crank but not start. I removed the pcm again and made sure the terminals were clean and reinstalled it, same thing. So I removed the pcm and removed the tuner and reinstalled the stock pcm and the truck started just fine. I noticed the display on the tuner will not light up at all, I looked over the chip/harness/display and there was no sign of damage anywhere. if someone could please give me some insite as to what the issue could be.
Thanks,
Jason
2002 F350 CC short bed, 3.73's, 3" leveling kit, 33" nitto's, cowl hood, 4" straight exhaust, 7" stacks, cold air intake, homebrew boost reg., wicked wheel, banks transcommand, Dp-tuner, and a really BIG wish list!
klipz is offline
post #2 of 17 (permalink) Old 10-03-2008, 02:20 AM
matthewd11's Avatar
Re: Just got my dptuner
did you "overclean" the terminals on the PCM?
matthewd11 is offline
post #3 of 17 (permalink) Old 10-03-2008, 02:26 AM Thread Starter
klipz's Avatar
there is some copper showing?
klipz is offline
post #4 of 17 (permalink) Old 10-03-2008, 02:27 AM
matthewd11's Avatar
there could be too much copper showing and damaged that port on the pcm board. You probably cant get a good connection and the chip is not powering up, thus preventing the truck from starting...
Is there alot of copper showing?
post #5 of 17 (permalink) Old 10-03-2008, 02:29 AM
If there is copper showing you went too far and the pins on the chip will be loose. But it may be that the cord from the chip to the switch is loose. You have to notch the plastic or you'll usually knock the connector loose at the chip.
Depending on how much copper you have showing you may need to re-tin the traces.
69W900A is offline
post #6 of 17 (permalink) Old 10-03-2008, 02:33 AM
matthewd11's Avatar
Or buy a new pcm.
post #7 of 17 (permalink) Old 10-03-2008, 02:34 AM Thread Starter
klipz's Avatar
how do you go about retining the traces?
klipz is offline
post #8 of 17 (permalink) Old 10-03-2008, 03:47 AM
with a soldering iron and solder, just like you'd tin any other electrical connection.
69W900A is offline
post #9 of 17 (permalink) Old 10-03-2008, 03:58 AM
Gregch
Gregch's Avatar
I accidently pluged the F5 gauge switch in upside down. It did start and run bad, but the gauge switch did not light up. Worth a check.
Gregch: 03/2000 RED F250 S/D 7.3 w/6 spd, Con-FE, F350 springs w/ Add-A-Leafs, MT 38" MTZ's, ITP reg. ret. w/bowl delete-in tank mods -AirDog100-A1000, AFE2 PG7, ZooDad, MBRP 4"SS turbo back-6"Smokers, DiPricol gauges, DP F5 w/hi idle-V-60T-80E-120R-140E, OverBoost Annihilator,HPX Flex line, CCV relo
Gregch is offline
post #10 of 17 (permalink) Old 10-03-2008, 04:23 AM
Proud PSN Sponsor!
Strictly Diesel's Avatar
Or it's in "POSITION 0"?
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
