need some help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-30-2008, 11:23 PM Thread Starter
Electrical Nomad
Mayday's Avatar
need some help
over the weekend i installed some new injectors and did a ITP reg return kit. problem is i can get fuel now. i have cycled the key probably 25 times and the fuel bowl is still dry. i can hear the fuel pump running so what gives?
2000 F250- hybrids, GT38R, ATS trans, mod IDM, ITP fuel system, and DP tunes.
Mayday is offline
post #2 of 4 (permalink) Old 09-30-2008, 11:39 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: need some help
Sounds like you hooked the return and supply up together???
Joe
CSIPSD is offline
post #3 of 4 (permalink) Old 10-01-2008, 12:08 AM
Layson's Avatar
Re: need some help
does the regulator show any readings?
Layson is offline
post #4 of 4 (permalink) Old 10-01-2008, 12:23 AM Thread Starter
Electrical Nomad
Mayday's Avatar
Re: need some help
ok i found the problem. holyshat i must of been tired last night. a piece of the regulator found its way into my fuel bowl feed line, blocking all fuel flow. lack of sleep due too much wrenchin this weekend.
no leaks as of yet, i am going to go finish the rest so i can fire it up. thanks for the replies.
Mayday is offline
