Bowl work for lowering CR??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 09-29-2008, 12:21 AM Thread Starter
DZL JIM's Avatar
Where is material removed exactly to lower CR?
A) Make hole/opening bigger?
B) Make dish deeper?
C) Take material off hump (sides, but leave high in the middle?)??
Combination of A, B, C??
Or ??
Thanks.
DZL JIM is offline
post #2 of 36 (permalink) Old 09-29-2008, 12:29 AM
Got Bost???
NyCowboy87's Avatar
Re: Bowl work for lowering CR???
I was going to do the same as we do on our pulling tractor and do a combination of A and C. Roll the edge of "A" back a bit to help with heat and take "C" down and leave a little peak in the center.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #3 of 36 (permalink) Old 09-29-2008, 12:51 AM
Plays with Motors
Machinist's Avatar
A little bit from "A" & "B" and more from "C" - taking away from "C" means you have to increase the ramp rate up to the point to keep the same swirl pattern in the bowl.
IE: http://s287.photobucket.com/albums/l...#37;20pistons/
I stole your cut-away picture BTW, I just measured thicknesses with 2-point calipers - didn't cut one apart.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #4 of 36 (permalink) Old 09-29-2008, 12:55 AM
Cummins Power
mech2161's Avatar
What would it cost for the machine work on all eight?
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #5 of 36 (permalink) Old 09-29-2008, 03:11 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Yeah, my pistons are going to look like that when they are done
Stock
PowerstrokeJunkie is offline
post #6 of 36 (permalink) Old 09-29-2008, 12:06 PM
Banned
This is a .020 Mahle I was working on when the lathe decided it wanted to kill me. It chucked it at me but missed.
Anyway, the piston was damn near done except for putting the long radius on the bowl lip. It's a 48cc bowl, and you can see that I didn't touch the bottom nor the little "hat" in the middle. The wall is a mirror of the stock wall, it's just opened up.
That's what mine look like anyway. Minus the carnage. If I did it again, I would probably lay the wall back flatter to open up the bowl ID even more at the top. Something more along the lines of a cummins CR piston.
Charles is offline
post #7 of 36 (permalink) Old 09-30-2008, 11:14 AM Thread Starter
DZL JIM's Avatar
Great!
Thanks for all the input.
DZL JIM is offline
post #8 of 36 (permalink) Old 09-30-2008, 12:40 PM
All done now
Arisley's Avatar
Bet that was a fun little episode. Did you have to go change?
Arisley is offline
post #9 of 36 (permalink) Old 09-30-2008, 12:58 PM
Sponsor
here is a picture of the pistons in Ben's pulling truck
UNLIMITED_DIESEL is offline
post #10 of 36 (permalink) Old 09-30-2008, 02:26 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Aries ?
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
