SD PCM into OBS for Performance increase??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 09-28-2008, 11:57 PM Thread Starter
Ok over at FTE a guy posts a questions as he is putting a 02 VDH5 PCM into his 96 truck. He hasn't got the trans working right yet but thats not the topic of discussion for this thread. He claims with a DI chip compared to DI tunes on the newer PCM he has better performance. I would like how that is possible. I don't believe it as. The SD PCM can't do anything else that a chip can.
So discuss and explain if possible
Link to thread
http://www.ford-trucks.com/forums/77...questions.html
tjbeggs is offline
post #2 of 27 (permalink) Old 09-29-2008, 12:03 AM
What else?
smokyred's Avatar
Re: SD PCM into OBS for Performance increase???
I hope he's going to re-pin the harness to the PCM, seeing as they do not have the same pinouts. I think he's barking up the wrong tree.
Dave
smokyred is offline
post #3 of 27 (permalink) Old 09-29-2008, 12:04 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
I can tell you that my Bronco with a MNM1 and AA injectors will kill a reg cab OBS with essentially the same tunes.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #4 of 27 (permalink) Old 09-29-2008, 12:07 AM Thread Starter
Can you explain why? All things the same I would think you can change programming the same no matter what PCM your using.
And yes from the sounds of it he has built a pigtail adapter for the PCM harness.
tjbeggs is offline
post #5 of 27 (permalink) Old 09-29-2008, 12:11 AM
What else?
smokyred's Avatar
But Dave, doesn't your Bronco also have a 38R among other non-stock parts? Also is that an OBS engine or SD engine you have in there?
Dave
smokyred is offline
post #6 of 27 (permalink) Old 09-29-2008, 12:14 AM
Originally Posted by tjbeggs View Post
Can you explain why? All things the same I would think you can change programming the same no matter what PCM your using. And yes from the sounds of it he has built a pigtail adapter for the PCM harness.
I used to think the same thing till I drove the Bronco for the first time, it weighs 6160 without me so it's on par with a reg cab 4x4 OBS as far as weight is concerned.
I also know you can take an early 99 truck and put a 99.5 PCM and get better performance with the same programming.
as for the "why" I haven't the slightest clue.
David Lott
post #7 of 27 (permalink) Old 09-29-2008, 12:17 AM
Dave
it's an OBS engine with stock SD turbo and a regulated return kit otherwise it's a 250,000 mile original engine.
David Lott
post #8 of 27 (permalink) Old 09-29-2008, 12:21 AM
What else?
smokyred's Avatar
Gotcha Dave, I thought I remembered it not being stock!
Dave
smokyred is offline
post #9 of 27 (permalink) Old 09-29-2008, 12:41 AM
Send a message via AIM to JohnT
FWIW My truck feels like its running stronger going from the XLE PCM to the NVK PCM.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #10 of 27 (permalink) Old 09-29-2008, 12:49 AM
aggie's Avatar
early99 to late does make a difference. Anyone noticed if you put a pmt1 file on a xle truck it will idle very very quiet and low?
aggie is offline
