400+CC Bcodes with .012 nozzles - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 09-28-2008, 05:59 PM Thread Starter
Starting Over
kainers's Avatar
Are stuffed in jizzy! unstreatable with out some tunes.The throttle is so touchy and choppy un freaking real.I put 50 miles on her last night so the air is worked out.
Tow setting prior boost was 40 maybe 35 trying hard now it is 50 with no clean exhaust in sight.I wouldn't mind leaving them in there if something could be done with the touchy throttle and the choppy load up when you are on the surface streets at a constant 45-35 MPH.
kainers is offline
post #2 of 27 (permalink) Old 09-28-2008, 06:09 PM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
Re: 400+CC Bcodes with .012 nozzles
wow 400cc with pmrs? Im sure all the low end power and touchyness could be tuned out. My insanity tune from elite is like that. Its hard to drive it down the road from 40-50 . Thats when it shifts to overdrive and starts jerking the truck around. U got to get rpms up to quit it
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #3 of 27 (permalink) Old 09-28-2008, 06:09 PM
Cummins Power
mech2161's Avatar
Sounds similar to the issues I had when I changed mine.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #4 of 27 (permalink) Old 09-29-2008, 03:17 AM Thread Starter
Starting Over
kainers's Avatar
just some stupid vid.i passed the camera to the wife so i could drive she tried.
kainers is offline
post #5 of 27 (permalink) Old 09-29-2008, 03:22 AM
Snake Oil Salesman
mattr66's Avatar
been working on the same issues on a truck with BD 350cc and 200% nozzles.. got it pretty streetable now put down 12.8 at the track yesterday with alot more fuel left in the girl.... You just have to re-map everything so it doesn't throw off your mass fuel and volume fuel calculations.
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #6 of 27 (permalink) Old 09-29-2008, 03:22 AM Thread Starter
Starting Over
kainers's Avatar
morning after
kainers is offline
post #7 of 27 (permalink) Old 09-29-2008, 03:23 AM Thread Starter
Starting Over
kainers's Avatar
oh yeh definitely needs some programming
kainers is offline
post #8 of 27 (permalink) Old 09-29-2008, 03:28 AM
10.61 @ 128 MPH
this is how my truck idles....it also could use some good tuning for everyday driving.
http://videos.powerstrokenation.com/...1800a17eed.htm
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Swamps Diesel
post #9 of 27 (permalink) Old 09-29-2008, 03:34 AM
2nd class citizen
1snotrocket's Avatar
i like the idle sounds like it has a cam. what turbo are you running?
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #10 of 27 (permalink) Old 09-29-2008, 03:35 AM Thread Starter
Starting Over
kainers's Avatar
I like the idle doesn't bother me.I like the lope.Your truck sure runs good
There had to have been something wrong with the hybrids.The truck use to die at stop signs and smoke like a mother at start up.That was with cycle'n the key 3 times.1st try it wouldn't start and if it did it sounded like it was running on 1 cyl.
kainers is offline
