Stacking on the 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-26-2008, 03:16 PM Thread Starter
AJF
AJF's Avatar
Stacking on the 7.3
I was always under the impression that if you had a chip and programmer the pcm would read the chip and override the programmer. But I have started to read stuff at some other places of people stacking this chip and that chip, and I didn't think it worked like that. Am I on the right track or am I off. Any insight would be great. Thanks fellas.
'01 F-250 7.3 4x4
Swamps, JWVB, DIY Intake, 4" MBRP Exhaust, IssPro Gauges, WW, John Deere Interior, 33" BFG A/T,
Ranchhand Legend Series Bumper, Mac Inc. HPO-X
AJF is offline
post #2 of 10 (permalink) Old 09-26-2008, 03:18 PM
Re: Stacking on the 7.3
i see charles is reading this so im sure he will explain it better than me. you have DP tunes so you have nothing to worry about really.
PMRCM#1
slowleak is offline
post #3 of 10 (permalink) Old 09-26-2008, 03:20 PM
Banned
When you attach any of the vendor's chips to the PCM board it substitutes it's own memory for that on the PCM board. So whatever information the programmer may have placed in memory on the PCM board, it's not being read from.
Now you can "stack" an ICP "chip" with a chip that goes onto the PCM board for extra ICP. But that's the extent of the "stacking" with the 7.3.
Unless you're talking about stacking the PCM with another seperate device that doesn't trick the PCM, but actually intercepts it's signals on the outbound side and then relays it's own. That would be another way to "stack".
Charles is offline
post #4 of 10 (permalink) Old 09-26-2008, 03:22 PM Thread Starter
AJF
AJF's Avatar
Thank you...this place is good!
'01 F-250 7.3 4x4
AJF is offline
post #5 of 10 (permalink) Old 09-26-2008, 03:23 PM Thread Starter
AJF
AJF's Avatar
No this was for somebody else...I am very pleased with my DP and aint going to anything else...except maybe that F6 chip
'01 F-250 7.3 4x4
AJF is offline
post #6 of 10 (permalink) Old 09-26-2008, 03:28 PM
Banned
I should add that some people also play with resistance values on the EOT sensor. But that is fire, and you shouldn't be playing with it. Period.
Charles is offline
post #7 of 10 (permalink) Old 09-26-2008, 08:20 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
So IOW you're stacking, right ?
Stock
PowerstrokeJunkie is offline
post #8 of 10 (permalink) Old 09-28-2008, 01:53 AM
2002 F-350 4X4
TPeqJR's Avatar
Send a message via AIM to TPeqJR
i put the banks 6 gun on my truck and felt a big difference, later i added the big hoss module (levle 4) and noticed no big difference. what can be the problem?
2002 F-350 4X4 CrewCab LongBed 7.3L
6" BDS Suspension Lift, Bilstein Shocks, 37" Toyo Open Country MT Tires
TPeqJR is offline
post #9 of 10 (permalink) Old 09-28-2008, 01:58 AM
look what i can do
1badpsd's Avatar
well the problem is YOU HAVE BANKS!!! custom tunes are the only way to go
1badpsd is offline
post #10 of 10 (permalink) Old 09-28-2008, 02:36 AM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
