Block Filler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 09-26-2008, 03:03 AM Thread Starter
Subject Matter Expert
PowerstrokeJunkie's Avatar
Block Filler
I want to give my block the utmost strength i can give it, so i plan on filling it as much as i can and still be streetable. Ive heard several ways to do it, only two inches from the deck surface, some say only to the bottom of the water transfer ports at the front of the block ( thats what im leaning towards ), or only a little bit at the bottom. I am not worried about excess heat, the truck is getting transformed into a really really hot street truck/toy, no prolonged heat soak or towing will go on. I might need to add another oil cooler as well, Air to oil. Ive heard Hardblok is the stuff to use, is there any special way to do it other than torque down the mains, fill one side, sit level, torque down the head on it and let it sit for a day or two to cure?
Thanks in advance
Stock
PowerstrokeJunkie is offline
post #2 of 18 (permalink) Old 09-26-2008, 06:30 AM
urbanwheeler's Avatar
Re: Block Filler
on all the street rods we put the piston at bdc and fill to the bottom of the ring's stroke. that will leave enough water in it to cool the rings and cylinder, oil should help cool the piston itself
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #3 of 18 (permalink) Old 09-26-2008, 12:06 PM
Banned
Re: Block Filler
The coolant won't run 1 degree hotter with the block filled almost to the top. And the oil should only average a few more degrees. Maybe like 5 - 10 degrees average.
It's not a big deal.
Charles is offline
post #4 of 18 (permalink) Old 09-26-2008, 07:56 PM
Got Bost???
NyCowboy87's Avatar
Re: Block Filler
Could you get away with just filling the block and running main studs without a girdle for a hot street truck.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #5 of 18 (permalink) Old 09-26-2008, 08:18 PM Thread Starter
Re: Block Filler
Charles, is your block filled almost to the top?
Stock
post #6 of 18 (permalink) Old 09-26-2008, 08:32 PM
Laces Out
bigrpowr's Avatar
Re: Block Filler
i used rockite from hartline products. better supposedly than hardblock. less seperation issues. get it grainger for cheap.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #7 of 18 (permalink) Old 09-26-2008, 08:52 PM
Shaw's Avatar
Re: Block Filler
I would like to know also?
"It's JUSTa 7.3"
His - 01 F-350 Reg cab 4x4 auto
Hers - 00 F-350 Crew long bed 4x4 auto
Kids - 01 EX Limited
Toy - 97 F-350 Reg cab 4X4 5spd
Shaw is offline
post #8 of 18 (permalink) Old 09-26-2008, 08:54 PM
fueled by Colecovision
golfer's Avatar
Garage
Re: Block Filler
yes, we filled Charles' block up to ~2" below the deck.
golfer is offline
post #9 of 18 (permalink) Old 09-26-2008, 10:40 PM
Shaw's Avatar
Re: Block Filler
Thanks for the info golfer! Didn't you guys run the heater hose port from the rear most ports on the heads? I thought I remember reading something about that?
"It's JUSTa 7.3"
Shaw is offline
post #10 of 18 (permalink) Old 09-26-2008, 10:48 PM
golfer's Avatar
Garage
Re: Block Filler
we added a coolant hose to the rear of the drivers side head (near #8), and tee'd it into the inlet to the water pump.
after the block is filled, you do need to drill/chisel out passages at the front of the block, and vertically at the rear of the drivers side (inlet to oil cooler).
just make sure that the coolant being pumped into the front of the block can go UP into the heads () and then back down through the heads, and into the block at the oil cooler.
take care~
Dave
golfer is offline
