Can't find the engine sr# - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-24-2008, 02:48 PM Thread Starter
moore20017.3's Avatar
so I am not sure if I got lucky or not. The valve cover tag is MIA. The date on the door sticker is 9-00......I am trying to find out if I have pmr's for sure. I am too lazy to open up the inspection hole. Is it possible to get the engine # from the vin# somehow?
My forged motor will debut in the spring with the hybrids and other goodies. I may be able to tear a little a$$ before then though and get the tuning figured out.
Thanks
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #2 of 11 (permalink) Old 09-24-2008, 03:18 PM
casper7.3's Avatar
Re: Can't find the engine sr#
your esn is stamped on the block right next to the oil filter housing and the glow plug heater it should be verticle of the oil pan
casper7.3 is offline
post #3 of 11 (permalink) Old 09-24-2008, 11:56 PM
What else?
smokyred's Avatar
Originally Posted by casper7.3 View Post
your esn is stamped on the block right next to the oil filter housing and the block heater it should be verticle of the oil pan
Fixed it for ya.
The serial # is on a nice machined surface down there, meaning it's prolly rusty in that area. You may as well pull the plug while you're down there, you can never be too sure of what you've got........
Dave
smokyred is offline
post #4 of 11 (permalink) Old 09-25-2008, 01:17 PM
casper7.3's Avatar
thanks
post #5 of 11 (permalink) Old 09-25-2008, 10:25 PM Thread Starter
As soon as I get back from Nebraska I'll pull it and see. If they are forged I will drop the hybrids, 910's and prods in and let everyone know how it runs with the 70MM!
post #6 of 11 (permalink) Old 09-26-2008, 12:11 AM Thread Starter
Got to the motel and was already filthy....After finding out that the inspection plug is NOT 3/8'' square (like I thought when I crawled under there) It is not 1/4'' either. WHAT SQUARE DRIVE IS BETWEEN 1/4'' and 3/8'' WTF!
Several people looked at me under the truck rolling around with a beer and a can of Gold Bond. I could not read the stamp on block, with the help of Gold Bond powder they showed up like a wh0re in church.
The number was 1468863, if Howard's numbers are right I'm in for some early fun before the other motor is finished.
"Strokinearly99"
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1446713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Thanks Howard for the information I pirated off the ORG. I will still verify if I can get the plug out at home. What tool is req'd?
post #7 of 11 (permalink) Old 09-26-2008, 12:21 AM
Don't EFN worry about it
Aljay's Avatar
I would get a hunk of square stock and use that to get that pesky plug out.
But me im a hack at best And a tight wad sometimes.........
Tuned by T Wildman
Aljay is offline
post #8 of 11 (permalink) Old 09-26-2008, 01:30 AM
What else?
smokyred's Avatar
5/16 sqaure drive......
Dave
smokyred is offline
post #9 of 11 (permalink) Old 09-27-2008, 06:52 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Dave
Get a 5/16" faucet seat wrench, or (as Aljay said) a piece of 5/16 square stock and bend a 90* on one end (from Home Depot, Lowes, Ace...etc.)
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #10 of 11 (permalink) Old 09-29-2008, 12:04 AM Thread Starter
Sorry about my rant, I just did not realize that sizes other than standard socket drives were used on plugs. I will get to it when I can. I got the hybrids on Friday
