Stockish turbo options?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 02-14-2013, 10:31 AM Thread Starter
Diesel Guru
Ok I've tried to search and I really can't find what I'm looking for. I'm going to be going to a van turbo or one of the bigger exhaust housings with a WW2. I'm really trying to stay away from running a wastegate. Now with running that setup what kind of boost foolers do u guys recomind? Or do you guys recomind running with the red line unhooked and leave it at that? I'm guessing you still need to limit what the MAP sensor sees??
Chad
2002 F-250, Edge Evo, PHP tuned, 4' Straight Exhaust, Tymar Intake, 4' Pro-Comp Lift
chadder1313 is offline
post #2 of 30 (permalink) Old 02-14-2013, 12:20 PM
Caption This
444-4D's Avatar
Re: Stockish turbo options??
I have a new 1.15 housing for a truck turbo that I no longer need.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 30 (permalink) Old 02-15-2013, 02:57 AM
how much for the 1.15 housing
01grnstroker is offline
post #4 of 30 (permalink) Old 02-15-2013, 11:19 PM
Caption This
444-4D's Avatar
I listed in in the for sale forum. I think it is against the rules to post prices here.
444-4D is offline
post #5 of 30 (permalink) Old 02-15-2013, 11:26 PM
jaybuller's Avatar
I really like the way my stock 2000 turbo is now. I went with the mechanical wastage actuator from diesel site and their new ww2. My stock turbo screams now and I like the ability to control boost with the wastage. I have mine setup so it holds rock steady at 32psi. With the wastage cranked down I can hit 38 no problem.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #6 of 30 (permalink) Old 02-16-2013, 01:41 AM
Consider the drive pressure on the WW2 is considerably lower, the stock ex. housing looks good for a tuned truck and even stg. 1 injectors. The 1.0 would be good as well and may even pull a little harder up top. I havent seen any numbers yet with the WW2 and 1.0 to confirm it, though a few have stated there 1.0 and 1.15 spooled way faster down low.
My turbo build works very well for what it is. No surge/low egts/spools fast
Billet WW2
Ported compressor cover
TN high flow outlet
Ebpv delete ped.
UNDER PRESSURE is offline
post #7 of 30 (permalink) Old 02-18-2013, 07:40 PM Thread Starter
Diesel Guru
See that's the thing I really want a 1.00 housing but I may just keep the stocker for now. What's the cheapest and easiest way to rig up a boost fooler on these trucks?
Chad
post #8 of 30 (permalink) Old 02-18-2013, 07:44 PM
Biggest problem is a stock turbo isn't gona live long at hi boost ...just get a 38r...
Yes you need a boost fooler.
email:
Website:
OBSWIZ is offline
post #9 of 30 (permalink) Old 02-18-2013, 07:47 PM
10$ harbor freight preasure regulator i seen posted elsewhere, just cut the map line and install, and set till you no longer throw the overboost codes.
Just my opinion, but the
GTP38 and WW2 may now replace the 38R up to 400 hp. Will see, but with a better drive ratio, opinions on the stock frame might change down the road. I like the stockish turbo so far, hell its even rebuildable. Smoke a 38R and well, its expensive (some are better than others)
But now the 38R and WW2 are hammering on the door of 620 hp. Who would have ever thought that ?
post #10 of 30 (permalink) Old 02-18-2013, 09:04 PM Thread Starter
Diesel Guru
Yeah that's what I'm sayin. If I didn't have a dang PMR motor I'd get a 38r. But until I find a cheap set of rods or another motor I'm not to concerned with big horsepower right now.
Chad
