tymar vs. dfuser - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 09-23-2008, 03:50 PM Thread Starter
casper7.3's Avatar
tymar vs. dfuser
tymar vs. dfuser any one had expierence with either? i see some guys run the tymar, they look pretty similar but i didn't know if one would out perform the other?
casper7.3 is offline
post #2 of 26 (permalink) Old 09-23-2008, 04:38 PM
HarleyEdition78412's Avatar
Re: tymar vs. dfuser
Price wise, I believe the tymar would be a lot cheaper. If you ask around on here people will tell you how to make a tymar intake. Besides the price basically the same thing.
Current- 2006 Harley Davidson Edition F250 6.0L w/a "BUILT" engine, Unfortunately mis-assembled and installed by CenTex Diesel and a NAPD Heavy Hauler RACE SERIES Transmission
Previous- 2001 Platinum Edition F250 7.3L
SCT LW and FICM tuning-
Regulated Return fuel kits-
ENOUGH SAID
HarleyEdition78412 is offline
post #3 of 26 (permalink) Old 09-23-2008, 05:32 PM
DSTRBD's Avatar
Same sh!t, different name.
DSTRBD is offline
post #4 of 26 (permalink) Old 09-23-2008, 05:51 PM
OBS junkie
Cat_Rebel's Avatar
Homemade Tymar, cost less then $50.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 26 (permalink) Old 09-23-2008, 06:13 PM Thread Starter
casper7.3's Avatar
what did you use to get from the filter to the breather tube? is that what i see on here called diy intake?
post #6 of 26 (permalink) Old 09-23-2008, 06:23 PM
OBS junkie
Cat_Rebel's Avatar
I just use some 4" PVC pipe to delete the CCV & hook up the filter to the tube. You can order the filter from www.fleetfilter.com look for Wix #6637
RIP Will Iott
post #7 of 26 (permalink) Old 09-23-2008, 07:07 PM Thread Starter
casper7.3's Avatar
thanks for sharing the info
post #8 of 26 (permalink) Old 09-23-2008, 07:23 PM
racehauler's Avatar
4 or 5 inches of 4" exhaust pipe works very nicely.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #9 of 26 (permalink) Old 09-23-2008, 10:38 PM
JimTJr's Avatar
Yep, what Race hauler said, most areas have a large truck store, (Peterbuilt, KW, ect...) and they use the 4" for their medium duty trucks, also the intake systems for the semis. Reasonably priced too,
*48* Jim T. 2011 F-350 Lariat, CC, LB, SRW. White Platinum Metallic Tricoat. Black leather seats, I probably wont have*PMS,, with this one, at least no major attacks of it!
JimTJr is offline
post #10 of 26 (permalink) Old 09-23-2008, 11:14 PM
Back to Civilian Life!!
MILFORD's Avatar
I got my piece of exhaust pipe from a exhaust shop out here in the middle of nowhere. Little hole in the wall shop gave it to me for free.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
